gearhead
Originally Posted by redridge View Post
really? to drop the engine, crack open the tranny and fix. It aint gonna happen in the tri-state area.
I’m Guessing he dropped it himself and threw the gearbox in his trunk.
Old 01-19-2022, 02:51 PM
Nope, he dropped the engine and rebuilt the transmission. The guys been working on Porsche exclusively for 45 years and has the equipment to replace parts as needed. It was in and out of his shop in a week.
Old 01-19-2022, 03:06 PM
It's a 914 ...
stownsen914's Avatar
These threads can be interesting. Everything from "it's the linkage" to "just rebuild your trans."
Truth is, it may well be both. If it were mine, I'd look at the easy/cheap things first. Adjust clutch, linkage bushings, coupler (check the set screw too) fall into this category. If it improves enough to be acceptable after those changes, great.
If it isn't perfect and you don't like the idea of spending $10K or whatever trans rebuilds are going for these days, one option is to double clutch on downshifts. And/or skip the downshifts to first while moving.
gearhead
Then you aren’t posting a repeatable comp. most shops charge $800-1000 labor just inside the gearbox. Your guy hooked you up.
Old 01-19-2022, 03:12 PM
He’s a great guy that knows his ****! ScottShop Sarasota
Old 01-19-2022, 03:17 PM
That’s the path I took and think many others do as well. Once all the easy stuff was done it was time to bring it to a pro for an opinion. He asked me how the hell I was shifting it and I told I double clutch and he just laughed. Called him back 2 days later to discuss repair work and it is now fixed and smooth as silk.
Old 01-19-2022, 03:22 PM
Brew Master
cabmandone's Avatar
If you can't shift into 1 while moving, your synchros are toast. There's a good thing about not being able to shift into 1 unless stopped though, REALLY hard to do what I did and go 1/2/1 at 60 mph. After smoking my exhaust valves on 3 cylinders, I wished I hadn't refreshed my transmission.
As others mentioned, if you want you can get it shifting pretty well by doing a full clutch adjustment, check/replace tunnel bushings and coupler bushings, and then dialing in the shift coupler. But if you can't shift into first while moving, your synchros are smoked.
FWIW, I did my own transmission refresh replacing synchro bands, sliders and dog teeth. I also found the needle bearing under the stack needed replaced because of a broken cage. It's doable if you know how to read and follow directions. There's a complete wiki on how to do it.
http://porsche.wikidot.com/porsche-915-transmission-repair-tutorial
Nick
Old 01-20-2022, 09:05 AM
How-To: Porsche 915 Transmission Repair Tutorial Part 1 - Porsche Wiki
Kudos for doing your own work, no tools or time for me to get to that level. Anyways, Kirsten’s spring will bring the shifter back to the 3 and 4 neutral plane, you may want to look into it.
Old 01-20-2022, 09:21 AM
Tinkerer , who and where is he located: this 1800 dollar magician of whom you speak? At this point I am getting my race 915 box gone thru almost yearly....inquiring minds want to know, THANKS. Frank
Old 01-20-2022, 09:39 AM
Brew Master
cabmandone's Avatar
That's the thing, I have a Seine gate shift kit in my shifter. I have no idea how I did what I did. When the weather is decent I'm going to go out and play around with coupler adjustment. Only thing I can figure is I have my coupler on the jagged edge. The coupler takes a very... very small amount of movement to throw things off.
Nick
Old 01-20-2022, 11:05 AM
Wow, that’s worth shipping coast to coast! I think some builders will charge the “book” price (or book ++) even if it takes them half the book time for the rebuild (due to their expertise/efficiency).
We need to keep shops like this in business!
Old 01-20-2022, 12:17 PM
For those who have done it, how difficult is a drop engine and tranny refresh? What did you include in the refresh- synchros? seals? bearings? gears?
Assume time and access to a 2 post lift?
Old 01-21-2022, 05:07 AM
Originally Posted by Dpmulvan View Post
...and it will do things for your driving experience that a center fill gas tank can’t.
LOL.
Can anyone suggest a 915 rebuilder somewhere near central Florida?
Old 02-28-2022, 10:14 AM
Thank you. Will check him out.
Old 02-28-2022, 10:17 AM
Still here
pmax's Avatar
Any response from the OP ?
Old 02-28-2022, 10:31 AM
Can't speak to the cost, but here's the where...
Scottshop Porsche Repair
Address: 5656 Jason Lee Pl, Sarasota, FL 34233, United States
Phone: +1 941 923 1382
Hours: Open · Closes 5PM
Old 02-28-2022, 10:39 AM
When I bought my 3.2 12 years ago I thought the 915 was toast. Shifted horrible. But I was used to a mustang GT. Then I changed bushings, gear oil to Kendal and a super pro on this sight told me to “ Don’t do what you want the 915 to do, do what the 915 wants you to do”. Ever since then my car shifts fantastic. Never been rebuilt. 166,000. Also new clutch and flywheel.
Old 02-28-2022, 01:30 PM
For the record, my rebuild was closer to $4,000, on top of having to find and buy a new (used) nose case and shift rod due to issues we found. And I dropped the engine/trans myself and delivered it.
Parts alone were $1,200 (2 syncros, dogs, shift fork, TO fork, gasket set + seals, reverse switch, , etc.,etc).
Some of that is no doubt CA pricing and using an expert with 40+ years of Pcar experience, but it drives fantastic now.
Old 03-01-2022, 05:36 AM
Got an update….
Ended up pulling the engine over the winter (first timer, massive thanks to everyone on forum) and getting the tranny rebuilt. I ended up replacing the clutch and flywheel and just got the car back together this past week. I can’t believe how much more enjoyable it is to drive and wish I did it sooner. Thanks everyone!
Old 05-29-2022, 02:39 PM
Glad to hear it. It is too easy to procrastinate. “So what if I have to bring it to a full stop to get it in first…”
Did you have the gearbox done locally or ship it? Curious if you can recommend a shop.
Originally Posted by ChuckleBeast View Post
Got an update….
Old 05-29-2022, 03:40 PM
