Help!! 915 output shaft seal leak
I just resealed the gearbox on a 1981 SC. I've done this several times over the years on various other 911's without ever having any issues. But... on this one, I replaced the two output shaft flange seals with elring part number 999-113-183-40-M30 45x68x10. I was stunned to discover a profuse leak on the PS and a minor leak on the DS after a 5 mile test drive. I removed the PS seal and replaced with another brand new elring seal.
After a 3 mile run, it's leaking again. The PS is set exactly straight and 2mm recessed below the case cast and the DS is at 3mm. I tested the seal point where it rides on the flange after replacing the seal for the second time and is sits exactly on the shoulder where the original seal left its mark. Like I said, I've never had an issue with these leaking in the past. Is there more than one size option? Ever heard of elring having an issue with this? I've always used these seals and never had issues. Thanks for your input! http://forums.pelicanparts.com/uploa...1644970272.jpg http://forums.pelicanparts.com/uploa...1644970315.jpg http://forums.pelicanparts.com/uploa...1644970338.jpg |
UPDATE... I drained about 8 ounces of oil out since both sides are leaking and it made no difference. This isn't rocket science! I just can't believe this happening!!
Seals normally have size markings on them to indicate OD, ID, and thickness. Any chance you have the wrong size? Leaking at the ID I assume?
Not good news. I just replaced the seals on my Carrera with Elring seals, same part # as part of my functional refresh. There were no leaks before replacement. Engine and trans still out. Should go back together in a couple of weeks. Living in Maine it will be several months before I will take it out on the road. Who is the oem supplier? Is it Elring per chance? Unfortunately, thanks for the heads up.
Please keep us posted. |
I have a few seals here that are probably from a job 2 years ago if you want I can send. Like you said maybe a bad batch
I quit using the seals in the gasket sets, and use only Porsche purchased seals. I’d use Kaco seals if I could get them.
what is the oil you are using also ..it has been seen lately the quality of seals no matter which kind are getting worse..do try to reduce the length of the garter spring inside the seal..like this
start with cuttin about 3-4 mm https://www.youtube.com/watch?v=Q83YRYcSpDE https://www.youtube.com/watch?v=OYxcT40i700 |
Mach925, I should of said Elring gaskets sets have Elring seals, doesn’t matter how u get them, in a set or separately.
Slip it on the seal ring of the drive flange to be sure it's a decent fit before installing it in the case.
OE seals I have here say Kaco.
Agree with John, they have to fit well, no gaps. Be careful if you shorten the spring. Excessive seal friction won’t do your flanges any favors. |
OK - Problem solved. I received the OEM Porsche seals today. I took some photos of the obvious differences. The OEM seal has a double sealing lip and the elring has one. The OEM fitment on the shaft was slightly tighter than the elring. To be absolutely certain, I shortened the springs by about 3mm. Does not leak a drop. I've used the elring seals here before without issue, so there seems to be some quality control issues with the current batch at Pelican. It's obvious that the OEM seal design is far superior, so my recommendation is spend the extra $15 and forget about the elring in this application.
http://forums.pelicanparts.com/uploa...1645139224.jpg http://forums.pelicanparts.com/uploa...1645139224.jpg http://forums.pelicanparts.com/uploa...1645139224.jpg |
Caleb |
good investigation..i`ll go look at my stash tomorrow ..what seals i have...the quality sucks lately elring use to be the seals to go to..no longer....
Ivan |
Back in post #7, see what I mean.
You'd think the Porsche OEM seals would be available from some other source. I mean, Porsche isn't manufacturing the seals ...
Vaguely interesting topic! I haven't had a problem with the single-lip Elring seals, either in their kits or as individual parts. The double-lipped version is a nice bit of insurance, no argument, against debris getting in. However, looking at the design of the outer lip, it is for debris and not oil sealing. The inner lip with its tighter design and gaiter provides the oil sealing.
I make a practice of checking the condition of the shaft where the seal lip rides. Often I will find they have a groove worn at that point, and that can cause seeping. This is especially common with the input shaft. There are a couple of fixes for this. One is to locate the seal at a slightly different depth, so its lip rides on an undamaged bit of the shaft. Another is to install an SKF Speedi Sleeve on the shaft, pretty cool fix. When assembling, be sure to pre-lubricate the shaft where the seal rides. I use a transmission assembly lube, but a smear of gear oil will do the job. Cheers, |
Great timing as I'm about to replace these seals. I guess I'll pony up for oem
| All times are GMT -8. The time now is 11:22 PM. |
