https://www.vintagetraderaz.com/product-page/12v-vintage-white-led-headlights |
Seeing things like this and this on their website make me cringe. They also don't seem to show the actual products, just images of the lights turned on, which doesn't show you how well they actually work. These look promising, but I don't have enough information yet to say if they are recommendable or not.
SWB 912 - G50 Carrera - 986 Boxster - 997.2 911 Turbo - 958.2 Cayenne - 9Y3 Cayenne GTS SOLD: 958 Cayenne Turbo S - 997 Carrera 4S - 957 Cayenne Turbo Workshop Coordinator at Ehrlich Motorwerks instagram.com/patrickossenkop ehrlichmotorwerks.com |
Enginerd
I realize that headlights often times carry strong opinions. Some love the original look, others like the modern look. I agree with the previous posting that it is about safety, but with an element of design (IMO). I have been so disappointed in the H4’s that I was looking forward to an LED upgrade. Plus, I love the look. But that’s me and I know others probably shake their head at my car now and that’s ok. It’s MY car. Here’s a pic of my 911 Haus headlights. I love them. The look. The function. I call them transformational, the lighting was so dramatically improved it was just amazing.
![]() ![]() ![]() Sent from my iPhone using Tapatalk
1982 Guards Red 911SC, 1994 Riviera Blue RoW 993, 2020 British Racing Green Macan GTS Gone but not forgotten: 2017 GT Silver Turbo S, 2012 Guards Red 991.1 C2S, 2017 Carrera White Macan GTS IG: @pcar911fan |
TX
how was the fitment with the HAUS units... |
Enginerd
After reading about how many people have struggled with some of the offerings on the market, I was very concerned. Fortunately, I had no issues with the installation and they snugged up very nicely. I was very relieved. There are certainly a few technical details that absolutely can't be overlooked or skipped (two of the internal tabs have to be bent flat, as one example) but I took my time and didn't rush....they just fit nicely. I did replace my bezel/ring gaskets since mine looked like they might have been 40 y.o. OE gaskets.
Tx TX
I had read/heard the HAUS units had better fitment then some of the other suppliers.... I have new seals (actually using VW seals which are a better fit) if you ever have the units off, i d be interested to see pictures of what you had to alter? appreciate the help before i spend beaucoup$ |
Member 911 Anonymous
Hey Fellas
![]() Well I can personally attest to the fact these LEDs by Vintage Trader are extremely bright not just your "run of the mill" drop in but engineered to provide gentle non-blue white light, liken to incandescent but 3-4 times brighter compared to SW-Chip's 80 Watt H4s on his 3.2. He was very skeptical of the LEDs but he was impressed which is very rare :-) Mine are European H4's and I just used the LEDs. In the past I used HID's but it was hit and miss when the balast would turn on or not then I installed PIAA LEDs, great light but so dim, not much better than 60Watt Standard Bulbs. They paled in comparison to Vintage Trader's LEDs. While testing them I never realized the softer warmer light was more pleasing and less strain on my old eyes. I highly recommend them, especially if you have the Sugar Scoop lights as they are truly plug and play. They will also keep the original look of the car Jim Quote:
![]() ![]() ![]() Crap, I got allot of Stuff in the Garage RFLOL ![]() ![]()
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
I understand it can make us feel safer and more confident, even if we aren't.
^ yup. A lot of people see a blown out foreground/scatter and say WOW I CAN SEE EVERY PEBBLE MY LIGHTING IS SO MUCH BETTER but they're not noticing:
1. The light does not punch as far. Do back to back testing with a street sign or something reflective on a long straight road. LEDs rarely go as far as halogens 2. The super bright foreground reduces your EYEBALL'S ABILITY to discern things farther ahead, as the contrast is too much. That said, our US spec headlights when these cars were new was pretty much ****, so I would assume projector style lights exceed the original design in all aspects. Drop in LED bulbs tho? Skeptical.
IG@ADDvanced Youtube@ADDvanced www.gruvdesign.com |
The super bright foreground light you mentioned also comes into play when running fog lamps (you're out driving your fog lamps reach over 25mph) and having bright LED instrument lights or bright back-lighting from a dash mounted cell phone that cause your pupils to constrict, keeping you from being able to see as far down the road.
all great thoughts, but leaves me confused as to best approach re updating my HLs. HAUS units or not. Find a good Halogen and use instead?
puzzled Bob |
Bob -- if you're still running sealed beam/sugar scoops, you might want to consider starting with a set of drop-in H4 assemblies/bulbs and a set of headlight relays (the JWest ones our host sells are great) -- this will be a significant improvement over stock (once properly aimed) and only requires a minimal investment.
I have a hybrid..scoops look but an h4 beam (not sealed) so i should look for better bulbs or will the reflector in pace not take advantage of better bulbs. Any suggestions on Bulbs?
Post a pic of what you have.
Frank Amoroso 911 M491 / M470 coupes: 1987 GP Wht / Blk "Apollo" 1987 Gemini Blue / Blk "Gemini" 1989 GP Wht / Blk "Vents" |
The Jwest relay kit is an easy-to-install/cost-effective upgrade that I've also been using, but isn't the end-all solution, only addressing about 1/3 of the issue. Quote:
Remember the point of the relays is to save the hi/low switch in the column by diverting full light draw through the relay. The fact it shortens the path to the bulbs is a bonus.
Driver
IIRC, 9eleven is making a new headlamp with the quad lights. I don't see them offered on their website, but I've seen a prototype of them on a friend's car. I suppose you could give 'em a call and see when that's coming to market.
1987 Venetian Blue (looks like grey) 930 Coupe 1990 Black 964 C2 Targa |
I'm using these:
MORIMOTO BI-LED SEALED7 2.0 HEADLIGHT/DRL/TURN SIGNALS 7" ROUND sealed beam units Super bright Hi and Low beams - 2,400lm (Low), 4,300lm (High) Quad design DRL (Daytime running lights) replicating current Porsche LED headlight designs DRL's turn Amber on turn/flasher circuit Excellent Morimoto quality and DOT approved Easy install if already running 7" sealed headlights...A little more work if you're not, but plenty of Pelican articles about converting to 7" LED lights. ![]() ![]() ![]() ![]() https://www.morimotohid.com/morimoto-7in-sealed7-2-headlight?quantity=1 [QUOTE=Classic11;11652239]I have been debating for a while on what to do with my headlights, one of my H4's needs a shiny reflector and what i really want to do is go LED. Yes for better light but mainly for looks. I have looked for pictures but have a hard time finding a 911 with "Black" Led headlights. I think the dark would work well with the impact bumper rubber. Anybody done this conversion? Last edited by sc; 04-21-2022 at 03:54 PM.. |
Carmagic.us
Why do you sell them now ? Going back to original ?
For BA7s Dash LED, and External Marker LED go to carmagic.us - Now Luftgekühlt Emblems |
