Weight of a gallon of gas?
Can anyone give me an accurate weight for 1 gallon of gas?(100 Octane unleaded) Also, what does a 911 tank hold in terms of gallons. TIA
Cheers, James
You will never know the feeling of a driver when winning a race. The helmet hides feelings that cannot be understood. Ayrton Senna 1993 964 RS |
Don't remember weight, but my gas tank holds 22.5 US gallons.
2022 BMW 530i 2021 MB GLA250 2020 BMW R1250GS |
Metal Guru
I believe that it's 6.7 pounds per gallon.
Paul B. '91 964 3.3 Turbo Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, H&R Coilovers, ESB spring plates- 210 lb |
I think its 2.2 lbs per gallon but don't qoute me on it.
Pratt & Whitney Aeronautical Vest Pocket Handbook:
Weight of Liquids Gasoline Specific Gravity at 20 degrees C = 0.72 Specific Weight lb / US gallon = 5.87 lb/ cu ft = 44.9 Last edited by JWest; 05-21-2003 at 06:12 AM.. |
I always figure water at a pint a pound. The old sailors saw goes a pints a pound the world around. I don't, however, know that it is actually true.
Jeb '79 930 |
8.345404 pounds per gallon.
OOOPs, that's for water.... Gasoline is 5.8 to 6.5 lbs
Warren & Ron, may you rest in Peace. |
Water weighs apx. 8.34 lbs. / gal.
Gasoline weighs apx. 6.2 lbs. at 60 deg. F
Chris '75 911s 3.2 - Ice Green Metallic ‘87 951, '05 987 S '21 Jeep Gladiator ‘18 Tesla ModelX 100D, ‘20 Model 3 |
Somewhere in the Midwest
The density of water in air at 60F is 8.33lbm/gal. Gasoline relative density at 60F is 0.751. That's 75.1% of the 8.33 lbm/gal, so your gas at 60F is 6.26 lbm/gal. If you are really looking for a specific valvue, buy a hydrometer and measure it at the temperature you will be measuring at!!!
Gasoline weights between 75% and 85% of water.
Density of water is 1 kg/liter. Therefore gasoline density is between 0.75 and 0.85 kg/liter. 1 kg/liter converts to 8,32 lb/gallon Therefore the density of gasoline is converted to between 6.2 to 7,1 lb/gal |
From what I've read additives will influence the weight as well. For instance a gallon of Ethanol weighs 6.8 pounds. Therefore, your gallon of gas will most likely weigh in differently than my gallon of gas.
Detached Member
Texaco posts the density of their generic gasoline in their Material Safety Data Sheets as 0.7-0.77 which means its 70% to 77% the weight of water which is 6.7 pds per gallon. Therefore, gasoline weights 4.69 to5.16 pds/gallon
Hugh |
"Therefore, gasoline weights 4.69 to5.16 pds/gallon" Therefore, Texaco's gasoline weighs 4.69 to 5.16 pds/gallon. Would be interested to see the difference between Winter blend and "rest of year" fuel.
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
LOL..
More entertainment Souk, LOL....................Ron
(1)stand on bathroom scale, record weight (2)consume one gallon of gasoline, record new weight
max |
Detached Member
Made a mistake before. Water is about 8.33 lbs/gal. so at 0.7 to 0.77 density then gasoline is 5.8 to 6.4 lbs/gallon
Hugh |
Depends on octane and additives
lead or unleaded. Lead is heavy you know
72 911 Although it is done at the moment, it will never be finished. |
Senior Member
Tobluforu - you are correct, gas weighs anywhere from 6.2-6.8 lbs/gallon depending on the blend and other factors. Avgas which is closer to kerosene weighs in at 6.8 lbs/gallon. In the FA-18 you get very good at quick math to calculate what you've got left, or when someone in B.F. Egypt wants to know how many gallons you need for a top off. ( We think pounds.)
Chris 1988 911 Carrera Targa (driving project started JAN 2022) 1970 911E - Long since gone 1972 911 Targa - gone 1987 911 Carrera - gone Retired FA-18C Driver |
