George,
I did the test you asked. Car ran yesterday afternoon, just now I cracked open the 14mm FD to WUR connector at the WUR (I did not crack open or remove any other fuel line), pulled the hose up and away from the WUR, shook it and still not one single drop. Just like I remember. Garage temperature today is hotter than usual, overnight maybe 22, at time of test 28DegC. Note: 1981 sc us. Over 20000 km and only one or two double starts. The last time I was playing with the wur so it doesn't really count. If each trip is 50km, then 400 successful starts, and one double start. That's my car, what can I say. Should add, temperature of starts where I run was -5C to 38C. Mostly between 20 and 30C. I don't start in winter or below -5C in the garage overnight. Phil Last edited by ahh911; 05-31-2022 at 09:43 AM.. |
Clarification........
Thomas, I spoke to George yesterday for a while. During the conversation I emphasized that the culprit was not the CSV. For a cold start, you need a CSV. So focus on identifying the culprit that is causing a cold NO start. It is something right in front of our noses but have not thought about it. That is the reason I ran the 2 motors in the garage specially the ‘78 SC. The last time it ran was 2 months ago. And I am installing right now an SC motor that I purchased 2 years ago on my test stand for a start-up. Just to demonstrate how easy and simple to make an SC motor run. Hope to get this motor running before George’s (just kidding). I need a week to get everything set-up. Tony |
This was mentioned by someone earlier in this thread but not verified that i could find.
Was this part changed also? http://forums.pelicanparts.com/porsche-911-technical-forum/1020014-csv-flange-911-110-264-00-alert.html
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
Correct CSV flange.......
Pete,
I asked George about this CSV flange during our telephone conversation yesterday and said it has the hole. George, Please confirm the CSV flange. Thanks. Tony |
We're looking for sth, which has going bad over time whithout changing anything on the vehicle. So at least one thing has gone bad. We see that the cold CP is far too low, raises far too slow. This enrichens the mixture over all frontiers that the car won't start with the CSV. Without the CSV it will start after longer cranking. Either the WUR is bad or more likely somwwething else, because the fuel hoses at the WUR are dry after the car sits over night or several hours. From my understanding and what I've seen on my car is - there's always some fuel. But George reports there's not even a drop. And that's weird froim my point of view. My concern is the dry fuel control pressure line between the WUR and the FD. We see in the 2nd video that it takes way too long to fill it up and building some pressure... And if he got the car starts and runs, it runs fine George said, right? Thomas
1981 911 SC Coupé, platinum met. (former tin (zinc) metallic), Bilstein shocks, 915/61,930/16,WebCam20/21, Dansk 92.502SD,123ignition distributor with Permatune box as amplifier,Seine Systems Gate Shift Kit,Momo Prototipo. Want to get in touch with former owners of the car. Last registration in US was in 2013 in Lincolnshire/lL. Last edited by Schulisco; 05-31-2022 at 02:15 PM.. |
Thomas,
On my sc the line appears completely dry after sitting, but is it really? zero issues starting (over 20k km). You have fuel dripping out of the fd to wur connection the next day. Either I'm lucky, or it doesn't matter or there are conditions on shut down that we simply don't understand. My system is very... very original, no work was needed to recover any modifications to the engine or kjet, except for a new bosch fuel pump that comes with a check valve, I just changed it because it's cheap and I don't want to be stuck somewhere for such a simple replacment. 81sc, usa. Sorry, new injectors as well when the top end done two years ago, again cheap and just makes sense to replace. I'm always up for an improvement, cost is very low for most of these components, so if you can prove that there should be fuel dripping out of the line, then I can learn, or improve even further a very decent performing car. Just for your info, at 3500rpm, when the pedal is pressed to the floor, there is a shock of acceleration, so I assume my accumulator is acting properly. The acceleration doesn't let up either. This car has been driven it's entire life, so the fuel dist system has not sat. I've read that you've replaced several parts, probably more than me, either I am off factory, or you are. It would be great if someone else can verify or we can solve the discrepancy. Also, when the wur is cal'd right, it will start on first crank, warm/cold/hot so the basic intended functionality of the device is in order as well as all other elements required to keep the pressure up after shut down. I guess what I'm saying is, don't look too much into the FD to wur line dripping after sitting for 12 to 24 hours as a very important piece of information until more data has come in from many others. I've provided my facts, you have a different result, if no other info comes in then this dripping or not dripping is questionable in the attempt to solve the issue, at this point. It's a very easy test to do, took me two minutes, if and when this is solved, if fuel comes out the next day for George, I will be very happy to benefit from this post, was not expecting anything in return, we'll see. tschuss, Phil Last edited by ahh911; 05-31-2022 at 03:48 PM.. |
Just for Discussion....
This is a Technical Forum, feel free to discuss and disagree. This is how we learn from each others’ experience. Tony |
Thank you for the test. So no fuel from FD to WUR line after many hours engine stopped. Since your engine is always starting i consider your test valid. So no problem there. |
If you have the wrong CSV flange (without hole) then engine's rpm will not increase during cold start as the extra air from AAV and AAR will not pass. This is not my case. An easy way to tell if you have the correct CSV flange is to remove the corresponding hose from the intake boot , start the engine and put your finger on the hose open end. If there is vacuum present then the hole on the flange exists. I did this test also and believe me the vacuum is very strong... |
@ Tony
""""Hope to get this motor running before George’s (just kidding). I need a week to get everything set-up."""" Challenge accepted!!! One week deadline hahahaha!!! |
Hi Guys
Yesterday i went to visit a friend. Since i was there i hooked the car to his analyzer. Results: 1. CO% idle after basic mixture setting: 5.5% 2. CO% idle after adjusting the allen screw : 1.58% ![]() 3. CO% @3000 rpm: 0.69 ![]() Note the HC readings also. These engines had incredibly low emissions for that time! This is also a good indication that engine has no vacuum leaks. |
Many posts ago your idle mixture data was in the 2 to 2.5% range. This new data started at 5.5% before being adjusted to 1.58%? Did you determine why this difference existed? Has the change impacted the problem?
Go back to the beginning.........
George,
Please help me understand where you are now regarding your car status. Question #1: After sitting overnight, how many attempts (start) before you could make the motor to start? When I do this test, I just reach for the ignition switch through the window and turned the ignition switch. I do not touch the gas pedal. Share what ever observation you have noticed or anything of interest. Example: What are the control pressure readings versus time, etc. Give me numbers instead of using adjectives. Question #2: Could you re-start a warm motor after 30 mins? After an hour? etc. I want to replicate your problem/s so knowing your conditions is critical to my next test. Thanks. Tony |
If you read previous posts i reset the system to basic mixture setting. ![]() Yesterday i checked the CO% with the basic setting (5,5%) and adjusted to 1.58% afterwards. Thanks Last edited by leonardo911sc; 06-01-2022 at 04:36 AM.. |
I have provided numbers for all my tests. This is a technical forum and i respect that. Have conducted all the tests proposed from all parties involved into this thread. Thanks everyone one more time for your assistance. I need your help for a test. 1. Connect your pressure gauge 2. Prime the system. Start engine or pump 3. Let the engine relax for at least 12 hours. 4. Try to start without throttle, only key start (as you mentioned) 5. Compare gauge pressure raise with my video. 6. Does your control pressure take that much much time to build up? Video link https://www.youtube.com/watch?v=GPXHHIFnsUw Thanks |
Empty fuel line after several hours.......
Phil, There is nothing wrong with the control fuel line. The fuel in the line would slowly seep out through the WUR after several hours. And would be filled up again in the next start-up. What is critical is to have the system pressure present immediately during start up. The control fuel pressure will come next after the system pressure. To measure the system pressure in your CIS, you need the valve for the gauge closed and open for control pressure. This is the conventional way how the CIS pressure gauge is connected to your motor. You could leave the gauge installed and run the motor to measure the control pressure but NOT the system pressure. To overcome this problem, I installed 2 set of gauges. One for the control pressure and one for the system pressure. So at any given time the motor is running, I could monitor both control and system pressures simultaneously. But this is not for everyone. Unless you have a curious mind. Tony |
@leonardo911sc
I suppose that you set up the CO on the warmed up engine. Because a valid CO value for those cars is nowhere listed, probably nobody can tell you a evan a approximation of a CO value on cold start, they vary greatly from one vehicle to another... 1,58% CO (on a warm engine) is pretty pefect, afaik the euro SC starting '81 with 204hp should run between 1-2% CO. The topic of the discussion is "residual pressure" and yoiur cold start problems and that weird behaviour, that the car started without CSV far better. And you wrote that the WUR is in spec. But the video tells us another story. The CP should start above 1bar, better ~1,4bar. I already wrote that the CP raises from too low. The supposition was that either the FA or sth else is leaking and therefore the pressure is that low - and as you wrote that the WUR is in spec. Q: How did you verified the WUR that is in spec? Q: Did you already checked the check valve & the FA? Thomas
1981 911 SC Coupé, platinum met. (former tin (zinc) metallic), Bilstein shocks, 915/61,930/16,WebCam20/21, Dansk 92.502SD,123ignition distributor with Permatune box as amplifier,Seine Systems Gate Shift Kit,Momo Prototipo. Want to get in touch with former owners of the car. Last registration in US was in 2013 in Lincolnshire/lL. Last edited by Schulisco; 06-01-2022 at 05:19 AM.. |
I set the CO% with hot engine and as per spec you provided (1-2% CO). Thanks for that. WUR pressure setting: 1. Engine stone cold 2. Check WUR temp with infrared temp gun 3. Jumper fuel pump relay and turn ignition key ON 4. Pump working 5. Set cold pressure as per diagram spec with WUR power supply disconnected and vacuum applied. 6. Install the plug and wait until rising pressure at gauge gets stable. 7. ALL within spec. 8. Pump and check valve are new 9. Accumulator is new 10. Residual pressure test is above spec If you see the video the WUR will reach the 1.4 bar but takes long time. While cranking is below 1 bar. This is where i am focusing now. I will do some tests and let you know. Thanks |
Thomas, Tony,
I want to point out that the next start after I opened the FD to WUR line for the test asked by George, the car caught fire up as usual (csv & AAV* dominated), but then the rpm dipped to 400 for several seconds (Rich) then back up above 1000rpm. This was a unique start and I believe attributable to the opening to atmosphere of that line several hours earlier, requiring a re-build of pressure and a lower first 5 seconds of control pressure to evacuate the air introduced in the line. This tells me that even though the FD to WUR line looks empty, it's not filled with air, but I'd guess a vacuum, big difference in the meaning and understanding if that's the case. Phil Last edited by ahh911; 06-01-2022 at 06:17 AM.. |
Could you make 2 videos with the fuel pressure gauge connected to see how the pressure behaves after switching off the engine? 1. control pressure (not important if the engine is warm, but the WUR should have reached the warm cp) 2. system pressure Thomas
1981 911 SC Coupé, platinum met. (former tin (zinc) metallic), Bilstein shocks, 915/61,930/16,WebCam20/21, Dansk 92.502SD,123ignition distributor with Permatune box as amplifier,Seine Systems Gate Shift Kit,Momo Prototipo. Want to get in touch with former owners of the car. Last registration in US was in 2013 in Lincolnshire/lL. |
