-   Porsche 911 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=8)
-   -   2.2 engine removal (http://forums.pelicanparts.com/showthread.php?t=111927)
limble 05-23-2003 09:32 PM
2.2 engine removal
I'm pulling the engine out of my 70 911. Where is the best place to remove the oil lines? At the tank or at the engine? I have all connections soaking in liquid wrench so it should be loose by morning.
john70t 05-24-2003 01:27 AM
Couldn't say, but the safest way would be both ends and new o-rings for the cooler.
Also, try PB Blaster for a penetrant in rusty spots.
Cerbin 05-24-2003 01:40 AM
It doesn't really matter so much but be ready with an oil pan and some paper towels. I believe i removed the oil lines that were attached to the engine when i pulled my 2.2.
Patrick
dhaines 05-24-2003 08:46 AM
I always take them off at the tank. On my '67 there is a few clamps that attach the longer line to the engine, and they are much easier to get to with the engine out.
limble 05-24-2003 08:55 AM
Follow up ques. The nuts on the tank are massive 36mm and one is 32.5 mm if my memory serves me right and I got the dial calipers in there correctly. The half size nut doesn't make sense and it has what looks like a split in it. Does it require a special wrench? I know these tanks are expensive so I don't want to screw it up.
dhaines 05-24-2003 09:08 AM
I just use a large adjustable wrench. I don't remember anything odd about the nuts, other than one is a inside fit and one a flanged compression nut. They do take a bit of force to get them off. There is no place for a back up wrench on the tank side, so I guess we just have to hope it is on there solid. I don't know if your '70 is different than my '67. Good luck!
