-   Porsche 911 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=8)
-   -   front hood seal (http://forums.pelicanparts.com/showthread.php?t=1129467)
zacks76930 11-06-2022 10:49 PM
front hood seal
Do you need to take the bumper and front smile off to replace the front hood seal?
proporsche 11-07-2022 06:38 AM
no you do not..the only thing i remove is the vent grille..after make it a snug fit and after use 3m weater-strip adhesive--i use the yellow type..
Ivan
zacks76930 11-07-2022 04:17 PM
Thanks, the two little tabs that stick out from one end of the seal go under the smile. I did not know if I had to loosen the smile to get them out.
emac911 11-07-2022 04:42 PM
FWIW, the 3M yellow stuff is awesome. If you have never used it I urge you to follow the directions. If you do it sticks like super glue to your fingers! Very important to let it get tacky before sticking parts together.
proporsche 11-08-2022 01:25 PM
no need to remove the smile ,just push it under
Ivan
Mike Andrew 11-09-2022 06:16 AM
+1 on the 3M. Stuff is magic and worth every penny.
Whatever you do, don't use silicone seal. Many have an etching agent which can mess with your paint and lead to rust.
