1986 Porsche 911 Carrera 3.2 Targa windows not working
Hi everybody!. Looking in this forum I found different problems with the non-functioning of the windows but in my case it is different. Not only both sides don't work but the fuse for the windows is short-circuited (is "hot") and blows the fuse. Any idea? Defective relay? Thanks
Old 06-14-2023, 06:29 PM
Subscribing. Will
Get to Learn some electrical.
Check the fuse box. If there is a relay it will show up there. I am away from the car so can’t check.
Also maybe the switch is short?
Silver 1987 Porsche Targa Carrera
Build thread: 87 Porsche targa! projects tracker
Old 06-14-2023, 07:42 PM
Discseven's Avatar
I believe the window fuse is the one nearest the cabin. Of course prior owners (if there were) could have altered the stock wiring.
Karl ~~~
Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter
Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s.
Old 06-15-2023, 04:44 AM
Thanks Anjizkit, good points! Will do.
Old 06-15-2023, 04:46 AM
Will check that relay Discseven...thanks!
Old 06-15-2023, 04:47 AM
