82 Teflon fuel injection lines
Anyone know where I can buy the Teflon fuel lines. Those are the fuel lines that run from the fuel distributor to the injectors. I once watch a shop install them using a butane torch.
Thanks in advance |
Bel-metric.com polyamide. There is a factory tool for the job it really helps because it can be tricky getting a good seal
it's not leaking....it's just marking it's territory |
I was unable to source the correct size polyamide tubing from Belmetric the last time I made some. I had to order from the UK.
The tubing is Nylon 11.
This Thread has some excellent information on the topic: https://forums.pelicanparts.com/porsche-911-technical-forum/1021937-how-make-fuel-injection-lines.html
