Regenerated User
Parallel Batteries / Dual Batteries / Early 911s
My uncle has a country place, that no one knows about. He said it used to be a farm, before the motor law. '72 911T 2,2S motor '76 BMW 2002 |
Regenerated User
![]() Changing out my AGM batteries in the 1972 Batteries were from 2014, as they are 8 years old and won't keep a charge. Is there a method? Does it matter which one is connected or disconnected first? Positive, then negative ect..
Regenerated User
I found these AGM motorcycle batteries for under $50 each.
It is safest to disconnect the negative terminals first, then the positive. This prevents risk of accidentally shorting the battery if the wrench were to contact ground when taking off the positive terminal.
Ed 1973.5 T |
This is interesting. So when 2 batteries in parallel are charged the current (not voltage) is split between the 2 batteries. That means the 2amp trickle charge is only 1 amp per battery. Sounds like a good slow charge for these would be 4 or 5 amps. Although..they are smaller batteries than normal.
it's not leaking....it's just marking it's territory |
