kevbo's Avatar
Clutch slipping?
I recently replaced my fuel lines on the intake manifold and reinstalled the engine. After this the car would be real jumpy / jerky going engaging 1st and 2nd gears. If I let our real slow it or get moving a bit and try again I could accelerate real slow.
When reinstalling the clutch cable and other components I try to keep everything like it was when I removed it but you know how that goes. SO...
I removed the engine again and started my investigation into the clutch. Here are some photos so can someone let me know if you think these components need to be replaced / resurfaced, etc? Does the flywheel look ok?
Some history, the clutch was replaced 7 years ago or so and has about 10k miles on it.
The clutch disk is 7mm thick.
Kevin
1986 Carrera Targa
Old 02-04-2024, 02:26 PM
Check your tranny and motor mounts.
House producers wanted to end the show after season 8 to keep the enigmatic appeal of the central character and maintain the show's mystique. Ahhh The Mystique!!!
Old 02-05-2024, 05:24 AM
Check to see if bell housing studs have lost their grip, esp on the bottom.
Old 02-05-2024, 05:33 AM
