NEED CLUTCH HELP!!! pulease...
LOng time racer here but I srtill have not figured this friggin thing out,.... New Motor ( Knightrace) , new trans ( from Winders) all new clutch components: New 915 KEP PP stage 1 , TOB, Lightweight FW, fork is fine.. all from PMS, everything went together fine. the clutch cable is virtually brand new ...
but will not dis-engage. cannot shift. can only start motor with clutch fully depressed. cannot get into any gear.. nothing... just grind I tightened up the adjuster bolt on the actuator under trans. but did not help. the cable adjuster on trans ( Front-rear). ) is pretty much almost centered.... I did not screw with it.... yet.... maybe a bit biased towards driver.... I have not checked the clevis in front. , but the pedal is not bent in any way. wtf!!! else do I check? trying to get to pca lime rock tomorrow thank you. frank ... |
correction. motor starts fine with gearbox in neutral ( Whether clutch in or out) ...... so its in neutral but not stuck in neutral.... .. I can try to shift with clutch in, but just grinds the gears... ANY GEAR!! will not engage
Get ahold of Scott (Winders) and William (knightrace), who you got your parts from. They seem to be good friends. Ask them directly for help with the parts and pieces the supplied....
Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
shifter linkage or bushings? Coupler loose or slipped?
Banned
Is your pressure plate the right thickness for the Kepp clutch is what I would ask about.
You didn’t say what kind of disc your running, puck or organic, and did you change disc type?
Look in the bell housing make sure fork is engaged on both ends
check that the roll pin in the clutch pedal isn't disintegrating.
