AC Delete engine panel
I am sure I am just not using the right phrases in search, but cannot find anything WRT a block off plate for the engine bay after removing the AC compressor and bracket.
With my clutch done, I am on the home stretch with spring plates and sway bar bushings, so will begin the long process of prepping for electric AC next year. Will be nice to get the bracket out of there and clean up a bit. Is there a panel that is available and I am just not seeing? |
I did the full heat back-date AC delete on my 3.2 motor. As far as I could find there is no "delete" rear tin. I fabbed up some patch panels and tig stitched them in place.
I'm sure I have pics of what I did. PM me tomorrow if you'd like me to post them. Not at that computer... |
Thanks Solamar - will do.
FWIW, I just used some black silicone seal and gutter flashing, painted black, to cover those gaps. Easy on, easy off.
Block off plate
I built this removable plate out of sheet metal. I thought it turned out pretty good for not being a sheet metal guy. http://forums.pelicanparts.com/uploa...1679779921.jpg
Goatfarmer1970: I’m having trouble posting pictures on the forum. SparkysVega is neater than mine, so use his picture.
http://forums.pelicanparts.com/uploa...1679936005.jpg http://forums.pelicanparts.com/uploa...1679936005.jpg http://forums.pelicanparts.com/uploa...1679936005.jpg http://forums.pelicanparts.com/uploa...1679936266.jpg http://forums.pelicanparts.com/uploa...1679936266.jpg |
| All times are GMT -8. The time now is 11:17 AM. |
