dictoresno's Avatar
Correct Alternator/Fan V-Belt Sizes for 1986 911? 710 or 695mm?
the OEM Porsche belt that's on the car, which was new 10 years ago with few miles driven on it, is the 10x710mm part number 999.192.176.5A. this belt feels so loose and even after getting all shims on the outside of the pulley, its still horribly loose. I'm gonna order a new one but wanted to verify since the owners manual and Bentley say that 10x710 is correct, however it seems like both parts and different dimensions fit. is one correct over the other? I don't want to max out the shims again if the 10x710mm belt is too big.
I plan on cleaning up the pulley halves of any corrosion and reinstalling. could it also be bad shims?
1986 Porsche 911 Carrera 3.2
Old 06-01-2024, 08:24 AM
9.5x710
Times have it most supply houses ship 10x710
You can work with either.
Bruce
Old 06-01-2024, 09:18 AM
dictoresno's Avatar
Originally Posted by Flat6pac View Post
9.5x710
Bruce
I see according to the old spec book that 9.5x710 is the correct size, it just seems so loose as I have all 6 shims outside.
maybe its just because the belt is so old its stretched? the car sat for 10 years without driving after a full maintenance. so again, its a new belt, low miles, but sat on the car for years. why do they offer the 695mm belt saying it fits also? I would hate to grab some more 710's and have them also be very loose.
Old 06-01-2024, 10:19 AM
dictoresno's Avatar
when a new 710mm belt is installed, how many shims are you guys ending up with usually for a new belt proper tension?
Old 06-01-2024, 08:55 PM
917_Langheck's Avatar
9.5x710 is original, but 10x710 works too, as Bruce noted.
If 9.5 is not working for you, get a 10. Easy enough.
Old 06-01-2024, 09:23 PM
Jeff Alton's Avatar
The true 9.5X710 is a rare bird now. We buy Porsche branded belts from Porsche and they are 10x710. Do not fit quite as well.....
www.turn3autosport.com
Old 06-01-2024, 09:31 PM
dictoresno's Avatar
Well that’s why I’m unsure about the 710’s. Like I said I have all shims outside, proper torque on the pulley and it’s still extremely loose. So I was considering grabbing a 695 belt to see if that helps along with new shims. I grabbed two 710’s and one 695 to see which one ends up fitting best.
Old 06-01-2024, 09:33 PM
Well, if the 710s don't work, and the 695 does, you may have a Porsche. Hans and Fritz didn't always return from lunch sober.
Old 06-01-2024, 09:43 PM
dictoresno's Avatar
sounds about right. Thanks!
Old 06-01-2024, 09:44 PM
Following this, as I too have my six shims on the outer side since I preventively replaced my belt with an original Porsche branded in 2018.
Since then belt has always been very loose, even with all six shims out. No squeaking but I wonder if this is right.
Gilles
RoW 88 Carrera coupé
Old 06-02-2024, 03:07 AM
dictoresno's Avatar
When my dad had the belts replaced years ago, it was squealing immediately. I tightened it by putting five shims outside and one shim inside, and it was tight and stopped, but recently when I finally acquired the car, I ended up having to put the final shim on the outside, which did tighten it up a little bit, but once I took it for a 30 minute drive it became extremely loose again, which is, why I made this post.
Old 06-02-2024, 05:33 AM
I've used 710 belts on my '82 for 25 years. Three shims in, three shims out is where I end up. My philosophy is to loosen the belt till it squeaks, then tighten it up one shim at a time until it's quiet. It takes a little trial & error, but I run the belts about five years or so. Trying to keep as little stress on the alternator bearing as possible.
Old 06-02-2024, 08:52 AM
PCA Member since 1988
710x10 will be tighter than 710x9.5, so don't use 710x9.5, even if you find them. If that's still too loose, then go to a shorter belt. Something else to check: At the age and higher mileage many of these cars have, the pulley faces themselves may be worn enough to use up 1 or 2 shims. In that case, I would just use a smaller belt.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 06-02-2024, 02:29 PM
dictoresno's Avatar
I pulled my pulley off and cleaned the one half, which has pitting and grooving. I assume there's no saving this. I need to try to clean the fan side a little with a wheel and see if I can remove the rust. guess this isn't helping my belt issue.
Old 06-02-2024, 05:27 PM
lake wales fla
Magnesium fan housings distort and collapse over time is the biggest problem reducing the distance from the center line of the alternator shaft to the crank pulley resulting in a looser belt. Over the years anytime I replaced a fan housing it made a big difference in shim position usually requiring more shims between the pulley than the previous housing. Also that pulley halve is not helping you situation and I would definitely replace it.
Richard
Old 06-02-2024, 05:54 PM
dictoresno's Avatar
I was able to clean the fan side a little today with a fine grit sanding block while rotating the fan. its smooth now.
Old 06-03-2024, 06:46 PM
dictoresno's Avatar
got the new belts on with new shims and pulley. looks like the old belt was definitely worn thin, which was the cause of my issue not being able to tighten it further. hopefully cleaning the fan corrosion will prevent future belt issues.
Old 06-06-2024, 12:35 PM
That rough surface will wear the belt over time!
Old 06-06-2024, 07:28 PM
dictoresno's Avatar
It’s no longer rough. It was sanded down with a 400 grit sanding sponge until it was perfectly smooth. Doesn’t look perfect, but it is indeed smooth.
Old 06-06-2024, 07:39 PM
That should work. Now, don't let that engine sit for years collecting rust again! Drive the snot out of it regularly.
Old 06-07-2024, 05:55 PM
