Stainless Oil lines.routing check
Guys.Have finished fitting SS oil lines.I am using lens high rise hoses.Can someone please confirm the flow from engine, and return to tank is correct on this picture please.I cant recall how they originally run.Sure this image is correct.However,when I looked at the Elephant Racing image, they look reversed,or maybe just my eyes!
The first picture of the thermostat to the motor is correct.
Bruce |
Yes it's correct. Why did you use metal pipes instead rubber ?
Wysane z mojego M2101K9G przy uyciu Tapatalka |
Wow!
Joshuars - those are AC hoses in your photo leading to the dryer and condenser.
![]() Paul- Along the rocker, the inner or lower line is the Oil Feed to the Cooler, the outer or upper line is the Return to the Tank. Looks really good. I am happy to have helped. Len
