1988 Carrera
European Rear Fog Lights
Some years ago I installed a rear reflector with the two fog lights as used in Europe.
I ran a wire from the orig fog light switch to activate them. I now want to install the proper switch. The one that you pull out for the front flog lights and turn 1/4 turn to turn on the rears. Does anybody have a wiring diagram for an '88 Carrera using this switch? Does anybody know if the rear lights use it's own relay?
88' Carrera 79' SC gone (lost to Katrina) 75' Targa gone 72'914 gone 72' 914 gone too |
try to look at this..
http://forums.pelicanparts.com/porsche-911-technical-forum/167698-euro-rear-fog-light-3.html van
1985 911 with original 501 587 miles...807 226 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
1988 Carrera
proporsche;
Thanks. But no help in the wiring issue. At the present I'm running the wire from the switch to the rear fogs. I have the proper switch but no idea how to wire it up.
here
http://forums.pelicanparts.com/porsche-911-technical-forum/241146-911-rear-fog-light-wiring.html
1988 Carrera
proporsche;
Thats what I needed. Thank you so much. If I had only looked at page 2. Again Thank You.
