1988 Carrera 3.2 Euro - What O2 sensor?
I was about to get this O2 sensor for my 88 Euro Carrera 3.2 - this sensor has the single round connector:
Then I spotted there's another one with a second or different connector: Anyone know which is correct or will fit? My car is a backdate with currently no O2 sensor, so it's not possible to disconnect the existing one and take cues from that. And there are a selection of unconnected spare plugs in the engine bay. |
This guy at Pelican Parts is very competent with Porsche items:
John Hunter x260 / jhunter@pelicanparts.com Good luck. |
I thought that euro carreras had a premuffler, no CAT and no O2 sensor?
Euro Carreras were available with and without cat.
My 1988 Euro 3.2 Carrera with cat (930/25 engine version) has that round circular O2 connector from your Ebay link, it connects in the left side in the engine bay, near the fuel filter. I'd buy it from Amazon instead of Ebay however, might be a couple of €/$/£ more but they couldn't be easier about returns or warranties. |
Ivan |
Euro a nd USA models both spec the same O2 sensor, 965-606-126-01
RP wants €115 for the sensor, you can buy a genuine Bosch for €65 from Amazon with free shipping. Plus they have a no questions asked 30 day return and 2 year warranty, good luck trying that with RP on an O2 sensor... RP has a very good selection of parts and good prices on some things, but it sucks that they don't disclose what brand product you are getting (Pelican for example very openly states what is OEM, original Porsche, aftermarket and has different prices for each). And you can be sure that RP's return and warranty policy will never even come close to Amazon. I buy from all of the above and they all have their pros and cons, but I'm definitely not willing to pay almost 2x for the same part, with worse shopping conditions. So it usually pays off to shop around... Cheers, Lukas |
And if you have a CAT but no O2, not good! Also, you are aware that without the correct Motronic chip, the O2 system won't function by just adding a sensor, right? |
Ivan |
Ivan |
Yah, you are right about the brand showing would be nice,thou Ivan |
Totally agree with what Lukas says about RP.
I'm French, I live in France, RP is French, and I never buy from them. There must be a reason or two. |
living in Belgium, I always buy via ALPO https://alpo.nl/ in the Netherlands
cool thing is that there are real people behind the mailbox, they actually answer with knowledge on their mind. If you are wondering about a specific item, they mail you the parts number and pictures first, so that you can indeed confirm. Had zero issues with them... I also stopped ordering at RP because of the above remarks (you don't know what you gonna get) |
all this said ..still.going to original post...i would like to see the picture of the connector OP has ..
Ivan |
Sent from my SM-G988B using Tapatalk |
Do you have no cat or do you? Ivan |
In UK our test for this year of car is a few percent CO at warm idle, and I'm getting one or two percent too high. I don't recall the exact numbers. Thankfully I have a very understanding tester but I don't want to take too many liberties with him. I will check and post a pic of the plug in due course. I just haven't been back under the hood yet. Sent from my SM-G988B using Tapatalk |
1. The discrete circuitry for an O2 function, not the 0-261-200-051 ECM. 2. The EPROM has the O2 microcode. |
Anyway prior testing your 911 make sure you go for long hard drive to make the engine hot ,this way you have more chances to pass the test...if your number are not really way off too much.. Ivan |
Right looks like I have the right one. I have a few disconnected connectors
https://uploads.tapatalk-cdn.com/202...740e234725.jpg https://uploads.tapatalk-cdn.com/202...208a48a80f.jpg This one looks close but I suspect it's cruise control https://uploads.tapatalk-cdn.com/202...84491a1254.jpg But judging by other pics and posts I've seen this plugged up one is the one. Two of the pins are shorted by the plug. https://uploads.tapatalk-cdn.com/202...b47e54387b.jpg Thanks for your help guys. Sent from my SM-G988B using Tapatalk |
1st pic is heater blower
3rd pic is only used once in factory for ref position of crankshaft. No longer used after. Don't know about the other two. Don't have them on my car (88 RoW Carrera). |
Sadly I have other problems now. [emoji17] https://uploads.tapatalk-cdn.com/202...cb5f18c89a.jpg Sent from my SM-G988B using Tapatalk |
You have posted 4 pics, right?
- First pic is heater blower connector - Second pic (green connector) don't know what it is, never seen it. - Third pic is indeed the ref sensor connector used only once at factory - Fourth pic is presumably the O2 sensor connector, harness part to ECU. If so, you need to buy the very first sensor from ebay that you posted the other day and plug it there. But as said before, first check that you have the correct ECU that is able to manage O2 sensor, otherwise no good. My 88 RoW with 930/20 engine has no cat and was shipped with a premuffler without any O2 sensor and no harness for it. So I cannot tell for sure that this is correct. |
Yes, you're right, my apologies. Fourth pic was the sensor. So the sensor is fitted, it went in perfectly and the car is now behaving beautifully.
After a few shenanigans. https://uploads.tapatalk-cdn.com/202...d1d4fa0fa8.jpg Thanks for your help. Sent from my SM-G988B using Tapatalk |
just one more suggestion replace your fuel filter...it has been there since 2017;-) that is kinda too long
Ivan |
