Toe adjustment - 87 carrera
Ive dug and dug and tried to find a basic write up on how to adjust my toe so i can safely drive it to get a proper alignment, with no luck. Could anyone help explain how to do it?
Et voila --- fresh from the oven, toe adjustment workshop online since a few days.
https://nineelevenheaven.wordpress.com/adjusting-the-toe-on-a-911/
911 SC 3.0, 1982, black, US model – with own digital CPU based lambda ECU build and digital MAP based ignition control All you need to know about the 930/16 and 930/07 Lamba based 911 SC US models: https://nineelevenheaven.wordpress.com/english/ Last edited by AndrewCologne; 08-15-2023 at 04:42 AM.. |
This is exactly what i needed!!! Thank you!
Take note that the specs allow for 0 toe for front and rear within tolerance .
Do not get sucked into the idea that toe in is better . The rear goes to toe in on compression. Just my thoughts
Kermit, 73 RS clone, Just Part of the Team Chris Leydon ,Louis Baldwin ,Peter Brock ,Riche Clark Jerry Sherman ,Rob McGlade ,Donnie Deal Hank Clarkson ,Craig Waldner ,Don Kean ,Leroy Axel Gains |
Specs from Porsche are included in the link
Front toe: 0° Rear toe: 10' with ±10' tolerance Taken from the Porsche factory booklet "types, measures, tolerances" (Typen, Maße, Toleranzen)
911 SC 3.0, 1982, black, US model – with own digital CPU based lambda ECU build and digital MAP based ignition control All you need to know about the 930/16 and 930/07 Lamba based 911 SC US models: https://nineelevenheaven.wordpress.com/english/ |
Thanks Andrew
Specs from Porsche are included in the link Front toe: 0° Rear toe: 10' with ±10' tolerance, so-10 = 0 It gives the most predictable handling
Have heard that a driven wheel/tire naturally toes out from its axle-side due to the friction between the tire and road. A toe in setting supposedly compensates for this.
Karl ~~~ Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s. |
This information I am sharing, is not conjecture , this is real life experience .
Although all tires and sometimes the car as well, may like a very small variation in spec. A well set up 911 is one of the best handling cars in the world . They have an undeserved reputation for nasty oversteer . Most of the time it is a poor alignment . When the alignment is correct the result is fantastic . Every alignment needs to have at least 20 miles of testing , on a proper road and with an accomplished driver , that is the tough part . New tires need 200 miles to wear off the mold release compound . Have fun when you drive Ian
Kermit, 73 RS clone, Just Part of the Team Chris Leydon ,Louis Baldwin ,Peter Brock ,Riche Clark Jerry Sherman ,Rob McGlade ,Donnie Deal Hank Clarkson ,Craig Waldner ,Don Kean ,Leroy Axel Gains Last edited by icarp; 08-19-2023 at 12:46 PM.. |
I have a Hunter alignment machine and I set all my cars to zero toe. Just like it that way. (LOL, just set my golf cart to 0 also)
edit: IMHO, a good alignment is the cheapest horsepower you will ever find. Last edited by eastbay; 08-19-2023 at 04:58 PM.. |
