Instagram.com/timofthevalley |
kinda slow
She desperately needs some love after DDing for 3 years. Giving her a break this winter and gonna get the fan cleaned up, simplify some wiring, and clean it all up a bit. Finally bit the bullet and got rid of all but 2 vacuum lines, don't know why I waited so long.
1983 911 SC Coupe |
Here is the engine bay in my ‘74. I swapped in a 3.6 with PMO itb’s, modified an MFi airbox to work with the PMO’s, and backdated the heater feeds. Then I generally cleaned up the routing of everything and eliminated most of the unused wiring, trying to keep it all as simple and tidy as I could.
Brooke 1969 911 ST 2.8SS EFI ITB (Irish Green), 1974 911 3.6 ITB (Black) 1952 MG TD with F20C |
I’m running the Racetronix 1 liter catch can on the pass side just in front of the motor. I made some mounting feet for it so it sits on the chassis rail. Mine is plumbed into my airboxes, but it doesn’t have to be.
In the pictures above I was just running a 123 distributor. The coil was in the fuel accumulator/filter mount up on the front left. That’s been removed.
I just added an MSD for the performance gains. The wires join at a terminal block for easy maintenance.
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS Last edited by snbush67; 09-28-2023 at 08:10 AM.. |
Should have payed attention to the user name What's up Shane
Hi Tim. I’m here for you.
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS |
Uncertifiable!!!
Interested to know a bit more about this 2.5, please. Short stroke/long stroke, compression, P&Cs, mods to Webers, etc. and closer pic of left inner and firewall mounter hardware.
Thanks. Johan
🇨🇦 The True North Strong and Free 🇨🇦 Living well is life's best revenge- George Herbert (1593-1633) 2006 C2S, 2024 WRX GT, 911 hot rods on Pelican…. Evolution of a Carrera RST, and Sweet Transplant |
66 911 #302694
Original 2.0lt opened up to 90mm, original crank (66mm) so short stroke. P&C Mahle Euro RS 90mm 2.7 8.5:1 comp. S cams, 2.7 heads. S distributor Weber's were reconditioned and initial set up by Performance Oriented. Nothing special about the engine panel. Factory ballast resistor, Ashlock Tac adaptor, Blue Bosch coil, Faucet fuel pump, Beru voltage regulator. Best pic I have before engine install Thanks for the interest Joe D
My life is not a journey to the grave, with the intent of arriving safely in a pretty, well preserved body, but rather I will skid in broadside, thoroughly used up, totally worn out, and loudly proclaim ..... WOW WHAT A RIDE!!!!!!! reaperwear |
66 911 #302694
Better Pic
![]() A few wires were tucked after this pic but close to final Sent from my iPhone using Tapatalk
996 Coupe, 84 Euro Carrera, Cayenne S, BMW CS 30, 72 2002 Ti (gone) 72 911 Hot Rod, Healey 100M, Giulia 1300 Ti, Merc 280SE4.5 Colorado Grand 03-04-05-07-08-11-17-18 Tour Auto 04-05 RG #650 |
Before, during and after…
I had mixed feelings about this because while the engine bay was tatty looking, it was mostly due to time rather than neglect. Cleaning things up meant using some non-standard finishes, so it came out tidy, but never original again… ![]() ![]()
![]() '79 after 10 month rebuild & resto to almost stock. .
Karl ~~~ Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s. |
Love that James Bond plate camouflage.
1986 911 Carrera Targa 2022 Macan |
Uncertifiable!!!
Cheers, Johan
🇨🇦 The True North Strong and Free 🇨🇦 Living well is life's best revenge- George Herbert (1593-1633) 2006 C2S, 2024 WRX GT, 911 hot rods on Pelican…. Evolution of a Carrera RST, and Sweet Transplant Last edited by Uwon; 10-01-2023 at 05:36 AM.. |
around 300HP sure helps a little bit moving...
87 911 3.8l |
![]() sounds better than it looks |
It's not easy being green .... or is it!
Kevin 1986 Carrera Targa |
![]() Always looking for ideas to clean it up even more. |
