Tire choices for a 77 911 narrow body. CN36, avons?
Hi folks,
Working on getting tires for my 77 911 narrow body with a 3.2 motronic engine. Car sits on 6x15 and 7x15 fuchs. Car came with a square setup for tires- 205 60 15 Falkens. Ideally I'd like to get period correct tires that are in the 25" height so it fills in the wheel well, but cannot find good brands with sizes. I'm thinking ideally 195 60 Front, 205 55 rear, or 185 70 Front, 215 60 rear. I do see Pirelli P6000, but nothing else.. Thoughts on other tire size combinations and brands that could potentially work? @bill verburg would love to hear from you as well! Happy Thanksgiving! Jake
71 911S 3.6 Rosewood 82SC 92 964 ROW- Sold 97 993 Coupe- Sold |
7 ET23.3 will rub on full compression a couple of inches above the lip, so ET that moves the wheel in a few mm is what is needed. The other tires are short enough to not be a problem lastly watch the f/r tire height, you really want to keep them relatively close to being the same
The RS spec sizes of CN36 seem like a no brainer to me, assuming the offset is correct. May be able to dial in the negative camber to keep from rubbing under full compression.
We have these on a 75 Carrera with 7s & 8s. So good.
SWB 912 - G50 Carrera - 986 Boxster - 997.2 911 Turbo - 958.2 Cayenne - 9Y3 Cayenne GTS SOLD: 958 Cayenne Turbo S - 997 Carrera 4S - 957 Cayenne Turbo Workshop Coordinator at Ehrlich Motorwerks instagram.com/patrickossenkop ehrlichmotorwerks.com |
also '73 - '75 RS spec was 6 & & x15 185/70 and 215/60, widest wheel specs for these sizes is 6 & 7.5", Though the factory did offer them on 7 & 8 in '75 & 76
71 911S 3.6 Rosewood 82SC 92 964 ROW- Sold 97 993 Coupe- Sold Last edited by jakg104; 11-22-2023 at 02:23 PM.. |
Mr. Merk, the issue will be that the RS/Carrera has wider rear flares, the narrow body is, well, narrow. Would have been easier if it was a Carrera flare car..
Full Send Society
215s will fit on 7” Fuchs in the rear. You’ll need between 1.5-2 degrees of negative camber and might need to roll your fenders, maybe not. All really depends on the tire profile but I had 215x15 Dunlop direzza on my narrow 1977 until I changed out to 6 x 15 wheels and taller tires for a more lively feel. Also Chicago potholes.
-Julian 1977 911 S: Backdate, EFI/ITB, AC project in the works: http://forums.pelicanparts.com/porsche-911-technical-forum/1106768-when-well-enough-cant-left-alone-backdate-efi-itb-ac-more.html |
Full Send Society
I have 6x15 aluminum steelies form Group 4 and I have riken raptors 195x65
Fat meaty and a lot of fun. The Direzzas were too rough of a ride and made the car boring.
I'm currently using Pirelli CN36 215/60/15 at the rear of my 70S, and P6000 216/60/15 before that. CN36 has way better grip, smaller dimensions, looks better, and I think (but not sure) lighter as well. Wheels are Fuchs 7R.
Looks great! Where are you buying the CN36 from?
Great to hear about the Riken raptors...
Jakg104, I bought them at P Zero World in Los Angeles.
Looks good. What is the thickness of the spacer you're using? And how much negative camber? |
Thanks blue72s, spacer is 5mm. Camber -1deg.
![]() ![]() ![]() I have a 75 narrow body and struggled with tire choices as well. I know this doesn't help if you stay with 15" rims, but I went up to 16" Group4 wheels because 16" offered more tire choices. I also didn't want to roll my fenders so I went with 195/55/R16 (~24.4 in tire height) Bridgestone POTENZA RE-71RS. They were a fraction of the price of the Pirelli P4000, but again this isn't helpful if you want to stay period correct. |
blue72s, with a 5 mm spacer the gap between toe adjustment bolt and tire is about 2.8mm. I’ll switch to a 7mm spacer, after taking the photo, It looks like there are tell tale signs that it lightly rubs on occasion.
In fact, the factory Sports purposes manual (1968) recommends 27mm spacer. . Last edited by blue72s; 11-25-2023 at 06:14 PM.. |
