Need a little assistance - '70 911 - anyone make single piece knee pad - ashtray del
Happy Monday to everyone.
I'm looking for a single piece dash knee pad kit for a 70 911. Im trying to delete the ashtray essentially and need a single versus 3 piece dash knee pad. I read that a 67 has a single knee pad - would that fit into the 70? Thank you
Old 12-11-2023, 10:25 AM
SWB cars.
206 637 4071
Old 12-11-2023, 11:03 AM
I'm not aware of an aftermarket 1-pc lower pad/bolster (although that would be great).
I have the SWB part in my 1970 coupe. the part dimensions work just fine, but my recollection is that you need to drill a new hole for one of the mounting studs before you can install it.
Old 12-11-2023, 11:08 AM
I recall Rennline might have had aluminum knee pad/lower dash cover full delete.
Old 12-11-2023, 11:20 AM
Super - thank you both!
Old 12-11-2023, 11:51 AM
Lz7w - would you have a part number?
Old 12-11-2023, 11:53 AM
90155203521
interestingly, it looks like design911 may now have a repro: https://www.design911.com/p/knee-protectors-lower-dashboard-porsche-911-1964-69/
Old 12-11-2023, 11:59 AM
I just went through this. Purchased a one-piece unit from Rosepassion. Pretty sure it was $500 shipped.
It arrived quickly, looks great and installed relatively easily. The vinyl is a close, if not perfect, match.
FYI: You will have to make/enlarge one of the mounting holes to get it installed. Fairly straightforward. A pivoting socket connection will make your life a lot easier.
Old 12-11-2023, 10:52 PM
+1 also- remove your driver side and passenger side dash air vents. Makes access heaps easier
Old 12-12-2023, 02:10 AM
Great, thank you everyone.
Old 12-12-2023, 06:41 AM
