Cold Start Valve Polarity ?
I had to replace the cold start valve Bosche Plug and now that it's installed Im wondering if by chance I reversed the leads on the plug from original.
Does not seem to be working like it did previously Does matter as long as wiring is correct from starter and TTS? tnx all! |
No Polarity…………..
Ray, The Bosch CSV has no specific polarity. It works either way. If you have OEM plug, it only goes one specific orientation. Tony |
thanks Tony much appreciated!
I did jump it out without the pump on and heard a click from the CSV so I suppose its working just fine |
Pressure Test…….
Ray, You need fuel pressure to test a good CSV plus 12 volt. Clicking sound is not enough to evaluate a good CSV. It might make the “clicking” noise but if the spray pattern is not good, then the CSV is defective. Tony |
I am back in business CSV seem to be working fine now |
