Nice! What is that battery is see in there?
ODYSSEY PC925s. You can buy them with the (+) terminal on the left or right side. Perfect for dual battery set-ups. But they are tiny. The battery boxes dwarf them. I had to rig up a method to secure them out of an eye bolt and velcro.
Landon - 1972 911T |
Wow. Great info.
Thanks. In 2006, I have ditched the dual setup for a single Optima on the driver side. I have noted that the this has not adversely affected handling.
PCA Member since 1988
4 years ago, I went to a single battery in the right box. I figured it would help compensate for my weight on the left side of the car.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
When I got the car back from the metal/body/paint fellow, it had a battery big enough for a diesel semi in it.
I had read about Harry and others going to a single-battery configuration. I like the quirkiness of dual batteries. Other than that, no advantage I can see.
I found the culprit! Here's the before shot. Note the hi-beam strip in contact with the power and lo-beam contacts. This was the lo-beam position on the stalk.
![]() Great tip on digging into that thing. After shot. ![]() Steering wheel removal was easier than expected but I'm sure glad I don't have to do that operation often. All those screws are flat-heads in the housing area -- what a pain in the a$$. I ended up using my squat rack safety beam to brace the wheel. Perfect height. Now I blind everybody on the road. Life is sweet.
| Tags |
| 1972 911 , headlight , wiring |
