-   Porsche 911 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=8)
-   -   1984 Targa engine pull, speedometer sensor wire? (http://forums.pelicanparts.com/showthread.php?t=1152865)
ErrorMargin 12-29-2023 10:08 PM
I am starting the process to remove my engine and transmission.
Do I need to disconnect the speedometer wire from the side of the transmission, or does that run through the engine harness connector?
john walker's workshop 12-29-2023 10:37 PM
Disconnect it in the shift coupler area and push the connector through the firewall. You'll be disconnecting the coupler anyway.
