Springloaded 915 shifter?! Yes, we can!
A friend of mine had a genius idea and it works stunningly well!
I installed it in my spare 915 shifter body. Incredibly easy. You install it from below. contact Instagram: @azul_minerva with this it holds the center position like a charm! ![]() ![]() ![]() ![]()
Regards, Flo / 79 SC streetrod - Frankfurt, Germany Instagram: @elvnmisfit Last edited by Flojo; 01-29-2020 at 11:43 AM.. |
Neat! Where did you source the spring?
Current: 1975 911S --Chocolate brown Past: 1967 911S --Bahama Yellow 1990 C2 Targa --Silver 1973 914 2.0 --Delphi Green |
As stated above, from Instagram: @azul_minerva
Regards, Flo / 79 SC streetrod - Frankfurt, Germany Instagram: @elvnmisfit |
Looks nice! But wouldn't the spring's constant pressure on the shift lever keep the shift fork slightly pressed against the shift sleeve?
It's spring load is not as heavy as on my WEVO for example.
I guess the benefit difference is, it's pulled load, from below, whereas the load on the WEVO is from the top, pressing down.
I had the seine (?) kit in my 85 911. when installing wondered why they provided another flange for the other side of the shift rod. realized it was to take the spring load off the gearbox gears when in the 1/2 plane. that goes with the one that holds pressure off the gears when in the 5/r plane.
always more than one way to ..... ![]()
Bob Cox 78 930 clone project car. 87 924S resurrect at some point. 84 928S, Ruby Red linen/brown interior - sold ![]() 86 944 turbo my new DE/track car - sold ![]() |
Perpetual Reassembler
Jose - 1983 911SC Coupe Instagram: @joe_engineer 911 D I Y Blog: joe-engineer d o t c o m D I Y Vids: https://www.youtube.com/joeengineer |
Hi,
Are these springs still available? Pre |
azul_minerva
______________ Karsten a backdated 1978 SC shell, a 2.7 with carbs and a couple of other Frankenstein mods https://www.instagram.com/azul_minerva/ |
Is this a Rip Off of your spring Karsten. If so very poor form!
That is Karsten's spring.
@azul_minerva = Karsten
'95 Coupe (2025-??) '86 Coupe (2021-2025) '82 Targa (2018-2022) |
Karsten, are you still selling these?
I would like to get one.
This spring still available? Interested.
