G series Bellypan
I think I need to change my fuel pump on my 2.7s 77 my. Looks like I don't have a front belly pan -weird I seem to have not noticed before !
Can someone post a pic of what my front underside should look like -incan see pics of later cars that leave the fuel tank open but I seem to believe mine should be covered ? Are belly pans available -a few searches is drawing a blank Many thks ans also welcome any comments on my fuel pump -it seems to buzz occasionally so time to change methinks before I get stranded somewhere! Many thks Andy |
Full Send Society
Fuel tank is exposed, skid guard only covers the fuel pump.
-Julian 1977 911 S: Backdate, EFI/ITB, AC project in the works: http://forums.pelicanparts.com/porsche-911-technical-forum/1106768-when-well-enough-cant-left-alone-backdate-efi-itb-ac-more.html |
Functionista
I tried to buy one new a few years back but the only one available was what came on later cars 87-89, which is different mounting than 74-77.
Jeff 74 911, #3 I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible. |
Maybe this will help. Although it does not show the skid plate that covers the fuel pump.
-Dave in Minnesota 96 C4 Cab, 85.5 944 82 SC Targa SCWDP #0023 82 928 67 912 60 T-5 B Cabrio |
Full Send Society
Here it is, #4 on the PET. It’s found in the section for front axle
The part number is in red. ![]()
Thks yes I have the protective plate 4 but should there not be a bigger cover over the front end ?
There seems to be some fixing holes unused ? |
Skid PLate
Rennline have a Skid Plate. It will cover the fuel tank and fuel pump.
https://www.rennline.com/porsche/911/body-exterior/skid-plates/ ![]()
1986 Porsche 911 Carrera Targa 3.2 Lt H6 |
Mark
1979 911SC Targa |
Banned
Seems like you could remove the protective cover of the fuel pump if you install the skid plate. Saves a little weight and work on accessing the fp.
John- 78 Slick Top 930 "Illegitimi non carborundum" |
Rennine support said you can leave fuel pump cover in place.
I changed mine recently and bought it new. There are two screws on the back side and hold the front sway bar together i believe on my 83 sc
