Kind of Blue
Can anyone tell me which part of the door handle assembly I broke?
The door opens fine from inside. It won't open from the exterior. The handle required quite a bit of force for a while and finally it stopped working altogether. I'd rather just have the part ordered before I disassemble everything.
https://www.youtube.com/shorts/z_oboeSi_lg
1971 911T w/ a 2.7 (ITBs, EFI, a bunch of other stuff, 2180 pounds with fuel) 2024 Ford Bronco Raptor |
to be quite honest, it is hard to say if anything is broken.It could be just the bolt loose which hold the little finger ...It is actually not that hard on your model to remove the door panel and remove the handle ,Once is out i`d bet you`ll see the problem ..
Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
Kind of Blue
Some of those outside handles have a finger that needs to be positioned between a "V" on the inner mechanism. If that finger is outside the "V," outside handle does not open the door. (Not sure if that's the finger Ivan is referring to.)
Karl ~~~ Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s. |
Kind of Blue
![]() So big surprise, the trigger failed. What is the proper solution? Just buy another handle? I see there are a few other trigger solutions but a search on Pelican says they don't fit or work well.
Kind of Blue
One more question - Does anyone have the Rennline drilled door handles?
I think they look slick but it says I need to swap the door lock mechanism from an earlier car. Is this necessary?
Well, what I see is the dove tail joint isn’t seated. The 5mm stud with the hex at the bottom is what secures that. Take a deep 8mm socket and try tightening the stud/bolt to reseat the trigger pin housing with the dovetail.
Kind of Blue
I did this. However, the trigger is detached from the hinge pin as this part of the trigger has fully severed, so when you press down, it doesn't fully extend the arm to tap the release.
The finger is broken,here is one for you on ebay.com from CA no.131232780510..ops i see now it is from renn.
here is one complete...375184131586 Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. Last edited by proporsche; 03-03-2024 at 02:33 PM.. |
Kind of Blue
Thanks, Ivan! I keep seeing '72 to '84 and mine is a '71. That should work, right? As I understand it, the punch-style handle is '69 and earlier.
i think if you would get the whole handle ,you would just have to replace the tumbler,it will work,,I just the finger from renn..i do not know..i`d get the handle if it was me
Ivan
I have bought repro triggers in the past & used them successfully.
techweenie | techweenie.com Marketing Consultant (expensive!) 1969 coupe hot rod 2016 Tesla Model S dd/parts fetcher |
Ivan
Kind of Blue
I bought that used one from eBay as it appears to be easier to swap tumblers and reinstall than it is to swap triggers, I think. I still may order the snazzy Rennline drilled handles but I need to figure out if I need to swap the lock assembly, which I really don't want to do.
1971 911T w/ a 2.7 (ITBs, EFI, a bunch of other stuff, 2180 pounds with fuel) 2024 Ford Bronco Raptor Last edited by MrBonus; 03-04-2024 at 04:28 AM.. |
Only ones I've seen are chromed. OE triggers seem to corrode long before the rest of the handle.
Kind of Blue
All the ones I found were black. Maybe I didn't look in the right place.
Unscrew the stud/bolt, take it apart, let’s see what’s broken.
the finger -trigger is broken you can actually see that..
Ivan
Kind of Blue
Of course, I dropped one of the mounting nuts into the nether region and have to hit the hardware store for a new one.
Ivan
