Grumpy old hasbeen
Door rattling - finally fixed?
On my ‘74 targa it had a problem with the drivers door - right door here in Australia. It felt like it only went onto the first latch, and made noises. First I suspected the window, the frame etc. I lost count how often I opened the door while driving to SLAM it closed, and that seemed to work. I played with the receiver in the doorframe, no success.
And today when looking for some other rattle in the car, I decided ti have a look at the door lock, mainly to see how much difference there was between the first and the second latch, and if there is a rubber buffer keeping the door under ‘tension’.
And then I found that the lock mechanism was loose. All 3 screws.
Stupid me, I would have thought I’d had checked that for sure…..
Have not had a test drive yet, but in the garage it looks promising.
Perth, Western Australia
'74 911 Targa
Old 03-21-2024, 01:24 AM
evan9eleven's Avatar
Thanks for the tip. I have a nasty door rattle that appears to be the window mechanism, but I'll be sure to check the screws holding the door lock bits in place too!
1981 911SC restomod "Minerva"
2004 Boxster S
2021 Cayman GTS 4.0 manual "Olive"
2014 Cayenne GTS V8 (wife's lover)
The slope is not slippery; in fact it is entirely frictionless.
Old 03-21-2024, 03:36 AM
