911SC Oil Leak
Looking for advice on the source of an oil leak. Pretty substantial oil leak from near cylinder six, dropping on the exhaust and smoking.
Just had the CIS out, replaced the seals in the triangle of death, so those are new. No signs of a leak there anyway, and I know the leak predates my recent ownership because it's always had oil dripping on the exhaust in that location. Valve cover gaskets are also new from recent service. Could this be coming from behind the oil cooler and involve the service bulletin/JB weld fix? I'm not sure where the oil comes out, if it is that. Hopefully not! Let me know what you guys think.
Old 05-08-2024, 03:44 PM
proporsche's Avatar
this looks like you rocker pin-shaft is either loose or misaligned to the wrong bor-side,
If you would take the valve cover of you should not see any oil in this place..on picture.
If yes have a look at the rocker shaft no 6 intake or exhaust.While there check them all ,of course..
your no 6 exhaust shaft position should look like this, for example
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 05-08-2024, 04:21 PM
Great feedback. I just went down a rabbit hole researching rocker shaft oil issues. I knew they had a tendency to back out but didn't know about the oil issue. I'll pull the valve covers off this weekend and inspect. Thanks!
Old 05-09-2024, 12:00 PM
PCA Member since 1988
If you are getting leaks at the rocker shafts, install the RSR O-rings on the shafts.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 05-09-2024, 01:27 PM
theiceman's Avatar
Originally Posted by proporsche View Post
this looks like you rocker pin-shaft is either loose or misaligned to the wrong bore-side,
Ivan
yup i had to do all this after i rebuilt my engine because i didn't replace the shafts, it was leaking exactly as ivan points out and running down the back side.
1976 Yamaha XS360 ( Beats Walkin')
1978 911 SC Targa ( Yamaha Support Vehicle )
2006 Audi A4 2.0T (Porsche Support Vehicle )
2014 Audi A4 2.0T Technik (Audi Support Vehicle)
Old 05-09-2024, 01:31 PM
Targa_PB_78_SC
mike sampsel's Avatar
And if you are installing RSR seals (which most recommend) get some of this to put a dab of lube on the seals. It's o-ring grease. Useful on the injector seals and other o-rings too. And the torque on the used shafts is higher than the new ones (around 18-20 ft lbs) on the used shafts for torque (keep them in place).
https://www.amazon.com/gp/product/B00IKUIO82/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1
There is no way I'd try to do the rocker shafts with the engine is SITU, I must drop the engine to get the room to do the job. But, if your only doing one,and your back is strong, and lots of space for words of woe then it can be done in SITU.
BareRearedRookie
Old 05-10-2024, 04:39 AM
GG Allin's Avatar
Check your cam tower plug also. On a fresh build recently I had a leak on initial start up that was from mine not being tightened all the way. That's exactly where it was dripping from.
1988 911 - 3.6
1999 SL500 - Gone
1995 M3 - LS2 - Gone
1993 RS America - Gone
Old 05-10-2024, 08:01 AM
Hmm, rocker shafts are in the correct position and tight along exhaust 4-6. No oil in that part of the vc shown above. The tower plug around cylinder six is also tight. Any other ideas? The vc is flat and not warped. I also believe all of the vc nuts were tight when I took it off.
Old 05-11-2024, 06:54 PM
proporsche's Avatar
That is good....but have you checked the intake side?You might as well since you are on it...
If not that take a picture where the cyl head meets the camshaft housing,that is the only place for this kanda drop of oil-leak.Also put your hand on the oil return tubes ,if you can spin them -the o rings are gone But if that would be leaking you would see this on the inside of the heat exchanger
Ivan
Old 05-12-2024, 12:38 AM
Targa_PB_78_SC
While your in there, check to see if the exhaust head studs are broken.
Pictures of the exhaust shaft positions, for posterity are nice too.
BareRearedRookie
Old 05-12-2024, 04:53 AM
I'll check the intake and exhaust studs tonight, thanks. Here are some photos of the rocker positions. Hard to get good photos, but the rocker bolt is flush or just proud of the thin side and well inside the thicker bore.
Old 05-12-2024, 08:19 AM
One more:
Old 05-12-2024, 08:20 AM
proporsche's Avatar
looks fine but..this place under the 6 exhaust.Is that a piece of old gasket leftover??
Old 05-12-2024, 11:43 AM
Thanks, proporsche, I noticed this too and will clean it up with a scrotchbrite before reisntalling. I slide my finger over it and its almost imperceptible, but maybe addressing will help.
I checked the intake side of 4-6 and it looks like each of the rocker shafts is improperly installed. They are all tight, but the shafts are flush with the BIG bore side, which I think is incorrect. That said, I don't see evidence of oil leaking down from the intake side to create such a big, dripping leak on the exhaust side (but maybe I'm just not seeing it).
One of the eight head studs on the 4-6 side was also slightly loose, by about a quarter turn. Others were good. Do we think the leak could just be from the gasket remnants? That would be great.
Old 05-12-2024, 01:49 PM
proporsche's Avatar
yup that is your problem..Just make sure when you relocate it the crank mark points to that cylinder.
It is kinda PITA on the intake when you have the engine in car but doable.Also adjust the valve clearance..and check all other rocker shafts...
And yes that is your oil leak....good luck ..you be fine after this repair
Ivan
Old 05-12-2024, 04:33 PM
Ugh, not looking forward to fixing this. Just replaced the airbox/CIS with the engine in, so let the adventures continue, I guess! I'll keep you posted. Much appreciated!
Old 05-12-2024, 06:31 PM
proporsche's Avatar
consider yourself lucky this could have happened.I had to do the whole engine for a friend.
Looks like you have nice garage, i would remove the engine-no need to remove it with the trany.
It will be much easier to work on it.
I think the shafts traveled in your case..here broken spring & bend valve on the 911 i have mentioned
Old 05-13-2024, 12:31 AM
Targa_PB_78_SC
I've pulled my engine a few times. Both engine and tranny every time. I've had problems lining up the engine and the transmission to get them together and as such, I am reluctant to take the engine out alone. I realize it saves some time, but getting things at the right angle to mate the engine and tranny is my concern. Having a lift for the engine where you can get it at the right angle helps a lot, I don't have one.
Think about doing all the shafts with RSR seals if you pull the engine.
BareRearedRookie
Old 05-13-2024, 04:32 AM
proporsche's Avatar
[QUOTE=mike sampsel;12248455]I've pulled my engine a few times. Both engine and tranny every time. I've had problems lining up the engine and the transmission to get them together and as such, I am reluctant to take the engine out alone. I realize it saves some time, but getting things at the right angle to mate the engine and tranny is my concern. Having a lift for the engine where you can get it at the right angle helps a lot, I don't have one.
I always use single floor jack .If you place it in the middle it is perfectly balanced..
One day i make a video so peeps can see it.No special tools need for it...Plus the alignment is also easy-will make the video too;-)
Ivan
Old 05-13-2024, 05:34 AM
Banned
Having done both I'd say it's much easier to do the engine and trans together. The one time I did just the engine I ended up dropping the trans as well and mating them before putting it back together.
Sure the CV joints are a chore, but it's better than lining everything back up in place, plus the hassle of the electrical connections and inaccessible trans bolts.
Old 05-13-2024, 06:01 AM
