windshield wiper frozen
Not the fuse...what else to check?:(
IT was the fuse 25 amp....but it keeps popping. Suggestions are welcomed :eek:
I would isolate the motor from the linkage. Can be done working through the clock hole I think. Remove the nut on the motor shaft and you will see if the motor runs or if the linkage is frozen.
When the fuse was replaced it turned a quarter rotation and then popped. Going to purchase some more fuses......I'll pull the nut, replace the fuse and see it works without tension.....
| All times are GMT -8. The time now is 10:26 AM. |
