Starting issue
81 SC 3.0 with CIS. Car has gone a refresh last year.
New wiring harness Repaired CDI Rebuilt dizzy New Clewett spark plug wires Hi-torque starter Plus many other items. Finally got around to starting it today but no success. Engine turns over, smell fuel, have fuel pressure, spark from coil to dizzy, checked that the spark plug wires are seated correctly but no spark on any spark plug wire to the spark plugs. Going to check the connection to CDI but anything else I can check?
Ravi 1974 914 2.0 1975 911s 3.0 2014 Cayenne GTS 2016 Cayman GTS |
Wires seated? Rotor in Dizzy ok?
Green wire from dizzy-CDI. Should be 600 ohms between the two LH terminals (top and bottom) as you hold the open plug looking at you.
Power to the CDI box? One of the terminals should have 12v - can't remember which but just try them with meter - other than the two LHS ones. Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-) |
OK - missed that - just saw no spark.
Alan
Will check all those items again. Thanks for the responses.
How did the car started before this problem?
1981 911 SC Coupé, platinum met. (former tin (zinc) metallic), Bilstein shocks, 915/61,930/16,WebCam20/21, Dansk 92.502SD,123ignition distributor with Permatune box as amplifier,Seine Systems Gate Shift Kit,Momo Prototipo. Want to get in touch with former owners of the car. Last registration in US was in 2013 in Lincolnshire/lL. |
Maybe engine ground wasn’t put back on if you did an engine out?
Yes car started fine before the refresh. The oil cooler leak was the cause of the refresh rabbit hole.
I checked for continuity between the chasis and the body and it was fine
Terminals 6 & 8 should carry the 12V. One is E and one +12V. Unfortunately I don't have the plug layout right now - but I think they are marked. If no 12V you will need to track back from that wire. Meter on either pin and other lead to an E somewhere should tell you which is the live terminal.
Alan
Start Up Problem……….
Ravi,
Were you using an inductive timing light for your start-up? It will tell you if you are getting good or poor ignition signals. It is very helpful to have one installed for your very first start-up run specially after an engine rebuild when so many things could go wrong. If you are getting strong ignition signals from the inductive timing light, then ignition is not the culprit. It is something else. Tony |
tried to post a pic for you, but not very good at that stuff.
As you face the CDI plug and the green wire terminals are LHS top and bottom, the voltage check wires are top row - far Rt, and 2 terminals along to the LHS, ie next to the top green wire terminal. If you are not getting voltage (12V) across these, you have found your problem. Alan
Update
Checked the cdi using site https://classic-retrofit.com/forum/index.php?/topic/491-cdi-quick-start-guide-read-this-first/#comment-857 12V between 31/1 and 15 -pass 600 ohms between 7 and 31d - pass I reseated all spark plug wires Tested continuity between dizzy and spark plug wire end - pass Checked timing - pass Removed spark plug from cylinder 1 and checked for spark - pass see image it was a white spark. Going to clean the grounds and check if other cylinders are getting spark. ![]()
So you have spark now? And no start.
Alan
How does the cap and rotor look? When you crank with the plug out (or with an inductive timing light attached) do you see sparking?
Maybe you put the dizzy in wrong . . 180 degrees off . . a couple teeth off?
Cap and rotor are brand new.
