Help with door handle and cylinder
Hi all,
I need to replace the door handle on the drivers side of my '86 Carrera. All of the photos etc I have looked at are for cars without central locking. My car has central locking, so I am uncertain what to do. I have attached a photo. I need to separate the handle and the cylinder so I can use the existing cylinder with the new (Pelican acquired) handle. Any advice would be greatly appreciated. Cheers Colin |
Its been awhile since i had my handles off but i remember using a long 1/4” extension to get the ? 8 mm? nuts off. There are posts here…
Thanks. I don't have trouble with the handle itself, but the part that has the wire running to it. I do see a screw on that part, but it is pretty difficult to reach. I think it is a fair bit easier on cars without central locking.
The wire has a connector in the bottom of the door and comes out with the handle, its a microswitch and youczn get to it after handle is removed.
I will give that a try. There didn't seem to be enough slack in the wire for that. Fingers crossed...
![]() This is similar to all of the photos I have seen. It is a relatively simple mechanism. This is not the case in my car. |
![]() ![]() Here are some photos from my car. |
You can unplug the connector inside the door to bring the handle to your bench to work on it
Great advice. Thanks!
