If you are referencing the CR AC blower box gen 1 and 2 then you should be blocking that off completely with the foam piece supplied plus an additional fill in. An even better method would be a piece of plastic, but the foam does a good job blocking. In a pinch you could use duct tape. Bottom line should already be blocked, so block accordingly.
83' Coupe - Ex-RaceCar
77' Targa Narrow Body - SC powered
Copper Brown Metallic
Old 06-13-2024, 12:57 PM
RDM RDM is offline
Coram Deo
RDM's Avatar
This is simply (ha! Simply!) a heat pump. It's how I heat my house, right down to the COP.
Edit: Does this qualify for the Federal tax credit for all-electric, energy efficient appliances? I think it's 30%.
Dru
1980 911SC Targa • Petrol Blue Metallic • Cork special leather • Sport Seats • Limited Slip • 964 Cams • SSIs • Rennshifter
• 1990 250D Opawagen • 1995 E220T Sportline Familienwagen • 1971 280SE Beverly... hills that is • 1971 Berlina 1750 Faggio •
Old 06-16-2024, 07:39 PM
Jonny H's Avatar
Absolutely! We are not the first people to use a heat pump in a car - most premium EVs have them now.
We are pretty sure that we are the first company to have a heat pump system that works at 12V and certainly the first to have one in an air-cooled 911!
It has taken a year of negotiations with the manufacturer to make this pump for us as well as testing both in China and the UK.
www.classicretrofit.com
Old 06-17-2024, 12:50 PM
RDM RDM is offline
Coram Deo
RDM's Avatar
Heat pumps (ducted or non-ducted) rated as "energy star" get a 30% tax credit.
Skylights with a solar-powered shade get you 30% credit on the entire skylight and the installation cost, so the law isn't exactly tightly written. Seems like we could work this.....
Dru
Old 06-17-2024, 02:53 PM
DIY wrencher
How has the testing been going Jonny, has the updated unit with proven as capable during the blistering hot (at least down here in Austria) summer?
88 911 Carrera 3.2 G50 - driver
77 911S - rust bucket backdate project
IG: @lukas.matzinger
Old 09-06-2024, 07:52 AM
jungspike's Avatar
Jonny, what is the timeline for getting this on the market?
84 911 Targa 3.4L
Old 10-09-2024, 08:35 PM
Jonny H's Avatar
Aiming to launch in March 2025.
Testing has gone well over summer with the AC - no noticeble drop in performance compared to the AC only system.
This will be the second Winter of testing. At 2,500W, the heating exceeds the output of a Webasto and will easily clear a screen AND heat the car.
Old 10-10-2024, 11:24 AM
evan9eleven's Avatar
Getting both heat and AC, and being able to run headers in the future, are the tipping point for me.
Johnny, will you take pre-orders at some point? I'll be reassembling my car this winter and in to next spring so it could be good timing.
With the new unit work with your Gen2 blower by the way?
1981 911SC restomod "Minerva"
2004 Boxster S
2021 Cayman GTS 4.0 manual "Olive"
2014 Cayenne GTS V8 (wife's lover)
The slope is not slippery; in fact it is entirely frictionless.
Old 10-11-2024, 02:56 AM
Awesome
This is a great timeline for a new product.
Thanks for all you and your team do Jonny!
Paul
83 SC The Herring
Old 10-11-2024, 07:14 AM
jungspike's Avatar
I'll be second in line behind evan9eleven on the pre-orders!!!
84 911 Targa 3.4L
Old 10-11-2024, 10:21 AM
MikeD930's Avatar
Jonny...can existing CR electric AC be retrofitted or will a new complete kit be required?
MikeD '87 930
Old 10-11-2024, 01:38 PM
DIY wrencher
Great to hear that Jonny. Will the new gen system also include a complete replacement of the (restrictive) stock blend valves and tubing?
Sounds like Julian and a few others have had great success improving air flow performance by doing that, even with the weaker/slower gen 1 blower fitted.
I don't want to speak for Jonny but he has posted somewhere that he plans to offer an upgrade kit.
Old 10-14-2024, 03:39 AM
DIY wrencher
Answering my own questions here, as I found some more info on the CR website under the news section:
https://www.classicretrofit.com/blogs/news/2025-is-the-year-of-the-heat-pump-for-porsche-911s
The new system now is going away from the stock mechanical blend valves and replacing it with servos and a new panel. Hopefully that now also means bigger diameter tubing throughout the system, which was a bottleneck on the old version.
There are a few sneak pics for the RHD cars, none yet for LHD though.
Target for start of sales is summer 2025!
Old 01-13-2025, 01:24 AM
Still hoping for an answer on this. Jonny?
Great info Lukas!
2004 Boxster S
Old 01-13-2025, 06:03 AM
I wonder also if they will fix the temp sensor placement so it's more foolproof in this new unit.
1978 911SC with Lobster Interior - Zoidberg
http://forums.pelicanparts.com/porsche-911-technical-forum/1126971-zoidberg-my-1978-911sc.html
Old 01-13-2025, 09:04 AM
Jonny H's Avatar
@Lukas, yes because the heat/cold is now 'sourced' only from the blower, the new blend valves do not need to be divided into 2 compartments for hot/cold as they were originally. This means the internal cross section is much bigger.
RHD is the more challenging install, because the brake booster is on the same side as the refrigerant lines. The lines are now custom aluminium hard lines (some with flexible tube) that fit snug around the frunk. The compressor/battery mount fits in the same space as the battery on a G model. This layout will be the same for LHD / RHD (so no smuggler's box version). Under the fenders, flexible lines are used which still allows for different condenser options.
@evan9eleven, yes the Gen2 blower can be used with the heat pump.
@jrwilson, the temp sensors will have dedicated mounting points.
We are currently in final winter test. I drove the car 200 miles on Thursday in just below 0 deg C. I got the cabin to 27 deg C so we are happy with that.
Old 01-13-2025, 12:28 PM
Jonny H's Avatar
Old 01-13-2025, 12:36 PM
Will there be an upgrade option for existing installations? It looks like everything is new.
Old 01-13-2025, 12:47 PM
Just curious on any updates here?
The AC $ystem I installed last spring is shot. And I deleted Heat when I had the rocker rust repaired (didn't install the internal ducting, committed heat delete).
Thanks!
Ian
Old 03-12-2025, 08:38 AM
Will the new compressor/heat pump still fit in the smuggler's box?
http://forums.pelicanparts.com/porsche-911-technical-forum/1114917-jedi-911sc.html
Old 03-13-2025, 01:35 PM
