If you are referencing the CR AC blower box gen 1 and 2 then you should be blocking that off completely with the foam piece supplied plus an additional fill in. An even better method would be a piece of plastic, but the foam does a good job blocking. In a pinch you could use duct tape. Bottom line should already be blocked, so block accordingly.
83' Coupe - Ex-RaceCar 77' Targa Narrow Body - SC powered Copper Brown Metallic |
Coram Deo
This is simply (ha! Simply!) a heat pump. It's how I heat my house, right down to the COP.
Edit: Does this qualify for the Federal tax credit for all-electric, energy efficient appliances? I think it's 30%.
Dru 1980 911SC Targa Petrol Blue Metallic Cork special leather Sport Seats Limited Slip 964 Cams SSIs Rennshifter 1990 250D Opawagen 1995 E220T Sportline Familienwagen 1971 280SE Beverly... hills that is 1971 Berlina 1750 Faggio |
We are pretty sure that we are the first company to have a heat pump system that works at 12V and certainly the first to have one in an air-cooled 911! It has taken a year of negotiations with the manufacturer to make this pump for us as well as testing both in China and the UK.
www.classicretrofit.com |
Coram Deo
Heat pumps (ducted or non-ducted) rated as "energy star" get a 30% tax credit.
Skylights with a solar-powered shade get you 30% credit on the entire skylight and the installation cost, so the law isn't exactly tightly written. Seems like we could work this.....
DIY wrencher
How has the testing been going Jonny, has the updated unit with proven as capable during the blistering hot (at least down here in Austria) summer?
88 911 Carrera 3.2 G50 - driver 77 911S - rust bucket backdate project IG: @lukas.matzinger |
Jonny, what is the timeline for getting this on the market?
84 911 Targa 3.4L |
Aiming to launch in March 2025.
Testing has gone well over summer with the AC - no noticeble drop in performance compared to the AC only system. This will be the second Winter of testing. At 2,500W, the heating exceeds the output of a Webasto and will easily clear a screen AND heat the car.
Getting both heat and AC, and being able to run headers in the future, are the tipping point for me.
Johnny, will you take pre-orders at some point? I'll be reassembling my car this winter and in to next spring so it could be good timing. With the new unit work with your Gen2 blower by the way?
1981 911SC restomod "Minerva" 2004 Boxster S 2021 Cayman GTS 4.0 manual "Olive" 2014 Cayenne GTS V8 (wife's lover) The slope is not slippery; in fact it is entirely frictionless. Last edited by evan9eleven; 01-13-2025 at 05:54 AM.. |
Awesome
Thanks for all you and your team do Jonny!
Paul 83 SC The Herring |
I'll be second in line behind evan9eleven on the pre-orders!!!
84 911 Targa 3.4L |
Jonny...can existing CR electric AC be retrofitted or will a new complete kit be required?
MikeD '87 930 |
DIY wrencher
Great to hear that Jonny. Will the new gen system also include a complete replacement of the (restrictive) stock blend valves and tubing? Sounds like Julian and a few others have had great success improving air flow performance by doing that, even with the weaker/slower gen 1 blower fitted. Quote:
DIY wrencher
Answering my own questions here, as I found some more info on the CR website under the news section:
https://www.classicretrofit.com/blogs/news/2025-is-the-year-of-the-heat-pump-for-porsche-911s The new system now is going away from the stock mechanical blend valves and replacing it with servos and a new panel. Hopefully that now also means bigger diameter tubing throughout the system, which was a bottleneck on the old version. There are a few sneak pics for the RHD cars, none yet for LHD though. ![]() ![]() ![]() Target for start of sales is summer 2025!
1981 911SC restomod "Minerva" 2004 Boxster S 2021 Cayman GTS 4.0 manual "Olive" 2014 Cayenne GTS V8 (wife's lover) The slope is not slippery; in fact it is entirely frictionless. |
I wonder also if they will fix the temp sensor placement so it's more foolproof in this new unit.
1978 911SC with Lobster Interior - Zoidberg http://forums.pelicanparts.com/porsche-911-technical-forum/1126971-zoidberg-my-1978-911sc.html |
@Lukas, yes because the heat/cold is now 'sourced' only from the blower, the new blend valves do not need to be divided into 2 compartments for hot/cold as they were originally. This means the internal cross section is much bigger.
RHD is the more challenging install, because the brake booster is on the same side as the refrigerant lines. The lines are now custom aluminium hard lines (some with flexible tube) that fit snug around the frunk. The compressor/battery mount fits in the same space as the battery on a G model. This layout will be the same for LHD / RHD (so no smuggler's box version). Under the fenders, flexible lines are used which still allows for different condenser options. @evan9eleven, yes the Gen2 blower can be used with the heat pump. @jrwilson, the temp sensors will have dedicated mounting points. We are currently in final winter test. I drove the car 200 miles on Thursday in just below 0 deg C. I got the cabin to 27 deg C so we are happy with that.
Will there be an upgrade option for existing installations? It looks like everything is new.
Just curious on any updates here?
The AC $ystem I installed last spring is shot. And I deleted Heat when I had the rocker rust repaired (didn't install the internal ducting, committed heat delete). Thanks! Ian |
Will the new compressor/heat pump still fit in the smuggler's box?
http://forums.pelicanparts.com/porsche-911-technical-forum/1114917-jedi-911sc.html |
