risky question - oil
hello everyone
I am working on a 1984 911 carrera convert. and I realize this can be a rough topic - types of oil - -I was looking at valvoline vr1 conventional in a 20w 50 weight - however when checking on valvolines site and others they say non compatible? i had thought i read on here or another that this was ok - or am I wrong - there may be better or different and you can let me know about that too (i am new to this i will gladly take all the suggestions i can get)
i am getting a Mahle filter and crush rings for the drain plug - in addition to the question about oil, is there anything else I will need? 10 qts correct?
thanks very much for any help you can give
Sean
Old 06-23-2024, 12:07 PM
If you use search you can find countless threads on oil.
I would advise you to utilize one of the existing threads as I don't know that the forum will benefit significantly by having an addition thread on the same subject.
Here's just one to get you started.
Old 06-23-2024, 12:29 PM
thanks - much appreciated. - i kinda figured from all the prior searching - there were more than enough threads - after sticking my toe in the rabbit hole - talked myself out of thinking i was on the right track - sounds like vr1 will work
thanks for the assist
Old 06-23-2024, 01:13 PM
Penngrade 20-50 is what use. Recommended from shop that built the motor. I used 12 but have a very large front oil cooler.
1975 911 3.4 outlaw/hotrod? lsd
1988 535i
1987 535is
1973 bronco ranger
Old 06-23-2024, 04:20 PM
Originally Posted by sb66 View Post
hello everyone
Sean
Perfectly suitable for your car, save on the reading.
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 06-23-2024, 04:35 PM
fallingat120mph's Avatar
VR1 in two 1986 3.2l for many years now.
One with 65,000 miles and one with now over 210,000 miles.
Holds up well here in south Texas.
The oil threads can indeed be a "rabbit hole".
Erik
1986 911 Coupe
1986 911 Targa
Old 06-23-2024, 05:25 PM
