-   Porsche 911 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=8)
-   -   Fan Shroud Crack: Keep or Replace? (http://forums.pelicanparts.com/showthread.php?t=1163642)
mziggy16 06-28-2024 08:18 PM
Just pulled the fan assembly to replace the alternator. Upon pulling the fan and housing I noticed cracks in the housing. I also noticed a spot where the fan is rubbing the housing. I assume what happened is that the housing shifted when removed because of the cracks. Does this need replacement? I think I know the answer here but want to confirm…
Also, assuming replacement, there are many options:
Rennline Billet
Aftermarket aluminum
LN Engineering Billet
Carpoint
FVD Magnesium
Anything to avoid? Any preferences?
http://forums.pelicanparts.com/uploa...1719630743.jpg
pmax 06-28-2024 08:46 PM
Fan housing, not fan shroud.
Originally Posted by mziggy16 (Post 12274224)
If that's JB weld, looks like it's holding up its end.
mikesarge 06-28-2024 09:55 PM
I would replace
Mike Andrew 06-29-2024 05:13 AM
That's some cracking!
I would replace with your choice which fits budget. New is probably not much more than penetrant inspection (Zyglo) to find more cracks, weld repair and coating to cover the repairs. Plus, it adds peace of mind.
gamin 06-29-2024 07:00 AM
I replaced mine with aluminum aftermarket, housing and fan. No problems and no worries about mag cracking, Looks better too.
walt 06-29-2024 08:28 AM
Too far gone, just replace it.
isby 06-29-2024 08:49 AM
I was not comfortable with the cracking in my housing and replaced it with the genuine Porsche (magnesium) housing. The fitment was not great, requiring a fair amount of honing in order to get the fan to spin freely in the housing.
E Sully 06-29-2024 09:00 AM
Extremely deep corrosion. The only choice is which replacement to buy. What does the fan look like?
ErrorMargin 06-29-2024 09:36 AM
I recently found crack in my housing and replaced it, my thread has details on all the replacement sources I could find:
https://forums.pelicanparts.com/porsche-911-technical-forum/1158384-replacement-fan-housings.html
mziggy16 06-29-2024 09:43 AM
Fan is in good shape, just dirty. Planning to have it powder coated.
http://forums.pelicanparts.com/uploa...1719679323.jpg
mziggy16 06-29-2024 09:44 AM
Helpful, thank you!
