-   Porsche 911 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=8)
-   -   1988 3.2 crappy idle and shakes (http://forums.pelicanparts.com/showthread.php?t=1165037)
Snitzler 07-30-2024 05:53 PM
1988 3.2 Carrera, first run of the year. Idle is not that great. Car shakes. ICV works and was cleaned twice just in case. New spark plug leads and plugs. Shop suggested valve adjust. Car is going in end of August. Any easy things to check?
https://www.youtube.com/shorts/DXdWNIc9GwY
EC900 07-30-2024 06:39 PM
How long was the storage period? Was there any short 10 minute start ups over winter?
Plenty of temp fluctuations I’ll bet. Moisture affected gasoline could be a culprit.
Gas tank/fuel stabilizer additive used?
How much gas left tank? Drain or syphon and fresh fill up.
I’d try and run the old gas out with an injector cleaner (proper ratio) at a highway speed for at least 50 miles (80k)round trip.
PeteKz 07-30-2024 10:25 PM
Pour a bottle of Chevron Techron Concentrate in the tank and drive it hard. If it doesn't smooth out, then start thinking about other things.
Re valve adjustment: When was that last done?
jlex 07-31-2024 03:55 AM
Could be a stuck injector. Put a long bladed screwdriver on each injector and listen to see if each is clicking.
Snitzler 07-31-2024 08:58 AM
Car was parked in my insulated garage. Stabil was used in the gas which was fresh and about 1/2 a tank. Never started during that time. I am going to fill it up and run some injector cleaner and run it hard for a while. I have one of those stethoscopes so will see if I can hear the injectors. clicking. Valves were done a few years ago.
PeteKz 07-31-2024 12:12 PM
Valve adjustment: Time doesn't matter. How many miles ago was the last adjustment? I would not mess with the valves if it was less than 10,000 or so. Just drive it.
EC900 07-31-2024 12:37 PM
I would not overdose the injector cleaner, it could cause other issues during the cleaning process like too much is not anlways better.
I always dilute at the proper rate per gallon. Stabil 360 is what I use, formulated for storage and cleaning whereas Stabil regular has less if any cleaning properties. I switch over to Lucas cleaners for 3 season driving.
Top off the tank with 93 or 94 octane non-ethanol if you can find it (at a marina). Shell nitro is a good detergent as is Chevron or Sunoco all depends on the market area. I’ll top off every few tanks with a top tier gas when I can find it.
Jonny042 07-31-2024 05:29 PM
If the new plug leads are Beru they could be the problem...
pmax 07-31-2024 05:49 PM
So, it was at a shop.
What have they checked ?
Snitzler 08-31-2024 01:34 PM
Further, shop was on holidays so goes in next week. Have been doing fast drives in 3rd gear around 4k rpm for half and hour on the highway, runs a little better. Did the stethoscope and all the injectors are clicking in time with the engine rpm. Quite surprised at how well you can hear the injectors. Car still idles like crap and backing off the throttle causes surging, like 3 times a second. I have to push the clutch in and clear the engine. Also really stinks like unburned gas. Last valve adjust was over 15k kilometres ago.
FA-18C 08-31-2024 03:31 PM
Maybe first consider changing the fuel filter.
FA-18C 08-31-2024 03:50 PM
https://forums.pelicanparts.com/porsche-911-technical-forum/1004817-3-2-pulsing-rpm-when-idle.html
Read this as well
nospiners 09-01-2024 07:35 AM
A smoke test , firing order and fuel filter is where i would check next..
FA-18C 09-01-2024 02:50 PM
I went through this 18 months ago and fuel filter and setting the idle stop switch fixed my problem. At the same time I replaced the fuel pressure regulator and damper and idles perfect now.
Cairo94507 09-02-2024 05:15 AM
MAF sensor issue?
Nick Triesch 09-02-2024 08:30 PM
Look for vacuum leaks. Tighten down the head runner bolts. Really. They come loose over time in a 3.2.
Nick Triesch 09-02-2024 08:31 PM
A vacuum leak can make a 3.2 idle like crap. As soon as my bad head runner gasket was replaced, idle went back to perfect.
Snitzler 09-17-2024 08:41 PM
Just got the car back, runs a lot better. Throttle body was removed because of silicon was found on sealing surface, cleaned silicon off and new o ring. Smoke test, no leaks. New ignition harness (BEHR) old one had over 100k on it. New plugs. Cap and rotor good but cleaned. New 02 sensor, over 100k on it. New fuel filter. Found vacuum line to fuel pressure regulator was disconnected (!), connected back up.
Engine sounds way smoother and engine doesn't shake. Idle is still a little up and down and slow to respond. Found that the ICV was “sluggish”. I ordered new from MAF Service. They changed the idle mixture, doesn’t reek of gas now. Checked valves, all good. Raining like crazy. Why didn’t Porsche use fender liners? When rain stops will do proper test run. Suggested that over winter, I should pull injectors and get them cleaned. Thats about it.
sundevil64 09-18-2024 03:24 AM
Some of what you are describing sounds like a vacuum leak.
mikedsilva 09-18-2024 04:47 AM
Sounds like that disconnected vacuum line might have been responsible for a lot
