1st batch of parts back from zinc plating
I pulled the engine and transmission from my 84 Targa and am doing a major refresh. I just got the first batch of parts back from plating for the intake.
I used a fine wire wheel brush on a bench grinder to clean everything up before I sent them out. I spent several hours on the wire wheel and it helped everything come out great:
Old 07-16-2024, 12:21 PM
Discseven's Avatar
Nice EM.
Are you inclined to share details.. Who did the plating, cost, time frame, problems if any?
Karl ~~~
Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter
Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s.
Old 07-16-2024, 01:41 PM
proporsche's Avatar
very nice-i just hope you had the fuel rails blocked
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 07-16-2024, 01:43 PM
tobluforu's Avatar
I need to do this, looks great.
Old 07-16-2024, 01:52 PM
The 9 Store
I do the same wire wheel on a bench grinder prep. I’ve tried lots of other methods but the wire wheel is good for 98% of the prep.
All used parts sold as is.
Old 07-16-2024, 03:39 PM
I used Cadillac Plating in Orange, CA.
I think it was $60 for the batch and took about 3 days.
No issues and the parts came out great!
https://www.yelp.com/biz/cadillac-plating-co-orange
Old 07-16-2024, 04:02 PM
Had a batch done in SFV, zero prep, came out amazing. Not worth the time to wheel everything imo. Infact I had sand blasted one of the brackets before, and could not tell them apart when I got them back.
Old 07-16-2024, 09:08 PM
DIY wrencher
Always satisfying to get back nasty old hardware from plating!
I agree however, probably not necessary to spend time wire wheeling anything. I dropped off all the metal hardware from an entire car, exactly as it came off, rusty and all as you see it below, and it all came out great. They do one or two acid baths before the zinc plating, so any surface finish or corrosion gets removed automatically.
1 by lukas.matzinger, on Flickr
2 by lukas.matzinger, on Flickr
3 by lukas.matzinger, on Flickr
88 911 Carrera 3.2 G50 - driver
77 911S - rust bucket backdate project
IG: @lukas.matzinger
Old 07-17-2024, 01:37 AM
That looks sooooo nice!
Andy Brian
Old 07-21-2024, 09:25 PM
Behind the Sun
Local platers charge by the pound.
The more the cheaper it is.
The hard work is prepping everything. Degrease, corrosion removal, dents, bends
Old 07-22-2024, 05:54 AM
The 9 Store
Same with mine. I prep and then it’s about $1/lb.
Old 07-22-2024, 10:06 AM
Senior Member
Any east coast sources?
Chris
1988 911 Carrera Targa (driving project started JAN 2022)
1970 911E - Long since gone
1972 911 Targa - gone
1987 911 Carrera - gone
Retired FA-18C Driver
Old 10-09-2024, 07:01 PM
Lukas, what are the wings for on the grinder? The one on the top left of the three.
Old 10-10-2024, 09:00 AM
DIY wrencher
I'm not sure what you mean with wings? The outer grinders have cords on them and the center one is cordless, they have a cutting disc, flap wheel, and poly disc (paint and rust removal) on them.
I added a couple of cheap cordless ones since then, so much more convenient to have them all ready to go with various discs to work anywhere.
Old 10-10-2024, 09:25 AM
theiceman's Avatar
its a holding rack for the grinder.
1976 Yamaha XS360 ( Beats Walkin')
1978 911 SC Targa ( Yamaha Support Vehicle )
2006 Audi A4 2.0T (Porsche Support Vehicle )
2014 Audi A4 2.0T Technik (Audi Support Vehicle)
Old 10-10-2024, 10:08 AM
DIY wrencher
Ah now I get what he meant! Yeah those are 2 steel mounts/racks next to each other, that hold 3 (small) grinders each.
Old 10-10-2024, 10:16 AM
Plating
Didn’t see this but I sent a batch to someone but did not understand what fully prepped meant.
Soak in white vinegar and old coating is removed.
Careful with magnesium though.
Just my 2 cents.
TOT
Old 10-10-2024, 12:34 PM
Gotcha. I guess I need one or two. Actually have that same grinder on the left which is what piqued my interest.
Old 10-10-2024, 03:08 PM
