CO spec for ‘77 US car
Hi all, I’ve been driving my ‘77 911S for a few months now after a top end rebuild and it has been great overall. However I have a cold start issue that has been annoying. It will start but seemingly on a few cylinders only for 30 seconds or so and sometimes backfire a bit. Then it fires all 6 and runs great!
I wanted to ensure my air/fuel ratio was good on this car and also my 79 928, so I got the GasTester a couple weeks ago. I finally busted it out today to check my well warmed up 911 and noticed that the ideal spec in the books for a US car is very different from a ROW car. The 1.5-3.0 for a US car and 1.0 to 1.5 for the ROW car.
Is this due to the emissions equipment on my US spec car? Since I’ve removed all of that, would I use the ROW spec? As it is, I set it to 1.6 at 960rpm and it seems to be behaving quite well though I can’t test the cold start until much later
Photo taken during testing - using my timing light to set the RPM
Old 09-02-2024, 08:12 AM
PCA Member since 1988
Yes, the differences in CO% are for different emissions requirements. If you deleted the US stuff, use the Euro spec, but feel free to adjust it a little richer or leaner to get it to run best.
However, that's probably not why you are have a rough cold start. Next step is to check CIS pressures, especially cold control pressure.
Does it start smoothly when warm?
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 09-02-2024, 12:17 PM
Hi, and thanks for the info. That’s what I figured!
It does indeed start well when warm. I’ve had the fuel distributor rebuilt by CIS Flowtech and have tested all the fuel pressures a few times to make sure they’re in spec.
I have an 033 WUR
System Pressure is 5 bar
CCP is 2.1 bar at 21C
I’m guessing I might have an issue with the cold start injector not working for long enough. It always fires right up - but then stumbles for 30 sec or so until it starts to run well
Old 09-02-2024, 01:02 PM
