We had a similar discussion earlier: https://forums.pelicanparts.com/porsche-911-technical-forum/1158127-air-sensor-plate-height-why.html#post12203484 Quote:
Check also both vacuum valves (flying saucers) on right side of the engine. JoeEngineer made some good notes about this: joe engin e e r dot com/porsche-911-cis-subcomponents-and-testing/ or https://rb.gy/vave3m Quote:
Had almost the same issues - couldn't get the engine run on ambient lower than 10°C / 50°F and when, I also had to push the accelerator 2-3mins until engine has warmed up a bit... Issues were: several vacuum leaks, WUR / wrong pressure, bad thermo time switch (and therefore no extra fuel from the cold start valve), and - applause, fanfare - a bad plastic flange at the cold start valve not letting any extra air through... https://forums.pelicanparts.com/porsche-911-technical-forum/1020014-csv-flange-911-110-264-00-alert.html https://forums.pelicanparts.com/porsche-911-technical-forum/1069752-cis-fuel-pressure-test-results-scrutiny-2.html#post11722791 This flange was mounted by the previous workshop without drilling a hole. So this way never any air could flow from AAR, start valve and vacuum limiter...:eek::o:rolleyes: Quote:
Thomas |
Schulisco,
Thank you for all of the information it has been a great help and pardon my ignorance this is the first CIS car I have ever delt with. Upon looking at the CIS manual about setting airflow sensor plate and comparing it to where mine is currently set. It looks like it might be .5-1mm to high in the venturi. its sitting level but the edge of the palte doesnt quite sit parrallel with the square part of the venturi. it looks like the thickness of the plate worth above that spot. My concern is that the level screw looks to have never been moved it still has the yellow paint on it. Ill try to move it down and report back. |
Joseph, Why is WCP only 2.5 bar? That is out of spec and hoping you were NOT using a HF pressure tester. My record says the WCP was set at 3.6 bar. Plus WUR-090 is NOT a vacuum assisted WUR. The post on top of the WUR should be connected to a vent (atmosphere) at the TB. Could you test again your fuel pressures and inspect the vent hose on top of the WUR? Thanks. Tony |
Joseph
Why is WCP only 2.5 bar? That is out of spec and hoping you were NOT using a HF pressure tester. My record says the WCP was set at 3.6 bar. Plus WUR-090 is NOT a vacuum assisted WUR. The post on top of the WUR should be connected to a vent (atmosphere) at the TB. Could you test again your fuel pressures and inspect the vent hose on top of the WUR? Thanks. Tony[/QUOTE] Tony, No its not a HF tester, I am using the one from the host site works much better. And yes will test again later tonight, wont hurt maybe I missed something. I have ensured all the vacuum lines are at the right connection. I have the WUR vent line going to the upper port on the front of the TB above the vacuum advance line. |
Also, would a low warm control pressure mean that the engine is running too rich all across the rpm range?
Had a break in between class and tested my pressures. Is about 75 F out maybe a little warmer engine was dead cold.
System Pressure valve closed http://forums.pelicanparts.com/uploa...1728429022.jpg Cold Control WUR heating element unplugged valve open http://forums.pelicanparts.com/uploa...1728429022.jpg Warm Control after 5 mintues with WUR heating element plugged in valve open http://forums.pelicanparts.com/uploa...1728429022.jpg |
Got my WUR back from tony and warm control pressure is right on the money at 3.6 bar. Car still starts hard when cold. Residual pressures are well within spec after hours of keeping the guage hooked up. Still have that pesky exhaust popping when under deccel. Checked for vacuum leaks again. Still no leaks although the test doesnt permit the install of the intake boot and oil breather lines. How does one smoke test with the entire system put together including the intake boot. Also am I just chasing a false problem with the popping because I have SSIs and a 2 in 1 out dansk sport muffler? Now at a total loss because WUR is working perfectly and still experiencing the same problem?
Here is a video of the popping when revving the engine with no load. Same as the popping under deccel.
https://youtube.com/shorts/RsruD6ZlwFU?si=t-RYT-XJyh-WwkA6 |
Leaking exhaust gaskets can also cause deceleration exhaust popping.
I haven't done that (yet), but I would try capping off the air intake or throttle body and push smoke in the tailpipe.
Since your wur was out of spec… do you suspect it was tuned to run well warm to compensate for the wur pressure being incorrect? If so, now that the pressures are correct, your mixture setting would now be wrong for both warm and cold.
If you now have a higher wcp, your system would be lean which could result in popping in the exhaust and hard to start cold. You can do a quick and dirty check by disconnecting the o2 and lifting up on the arm under the fuel distributor. If it starts to increase in idle a little then you’re lean. The idea is to get it to idle worse when slightly lifting up ( typically to rich and oscillates) or pulling down on the arm (starts to die). That means you’re very close to the ideal setting. You can get a far more accurate closed loop mixture adjustment by hooking up to the multi meter and checking the duty cycle - mixture setting. I don’t have a lambda but I know from reading you can do this without a gas analyzer. For me not having lambda in a 78 the arm test gets me really close then I use a gas analyzer. I may not be describing this perfectly so anyone else feel free to correct me if I am wrong. |
I am suspecting more and more of an exhaust leak since now the car runs perfectly in all loads and rpms with no hesitation and only popcorn pops when I lift off throttle. |
Well I think I figured out my cold start and mixture issue. I made a bone head mistake when putting my new air box in. I installed the wrong CSV flange. I installed an early version with the air line plugged instead of the later CIS version with an open air line. Took almost 7 hours to change it out but I didn’t need to drop the engine just patience and lots of small drive bits. Installed correct flange and fired up for the first time with no added throttle. Still making a popping noise under deccel but I am going in the right direction.
http://forums.pelicanparts.com/uploa...1731601539.jpg |
OMG
Had exactly the same issue years ago. Workshop replaced the correct drilled one with a new closed one like yours... I would drill this one ... 7 or 8mm should do the trick. Porsche part no. 911 110 264 00 Was also an issue earlier here: https://forums.pelicanparts.com/porsche-911-technical-forum/1020014-csv-flange-911-110-264-00-alert.html https://www.pelicanparts.com/More_Info/91111026400.htm?pn=911-110-264-00-OEM I recommend to order the rubber O-ring in conjunction as this is no standard sized ring with 20x2,5mm. Those standard O-ring are thicker and then the mounting of the CSV is even heavier as the CSV then won't sit flat and crushes the thicker O-ring... Thomas |
Made a discovery by surfing other forums on here, removing and plugging the ignition vacuum line made the popping disappear entirely and the car starts better. Havent adjusted the timing at all but it currently sits at 5 degrees BTDC at idle instead of 10 ATDC. advance maxes out at around 21 degrees. Hope this can help someone with the same set up as me.
| All times are GMT -8. The time now is 08:59 PM. |
