911sc - injector hard line for cylinder 1
In our newer to us ‘81 SC the hard lines off the fuel distributor are all mangled and bent weird and we want to replace them.
To that end I know our host has 2-6, but does not have the line for #1. Is this NLA at this point? Or does anyone have an idea of where to get one? Last edited by maverck; 11-09-2024 at 06:31 PM.. |
CIS Metal Fuel lines………..
Maverck, I have several sets of CIS metal fuel lines but I am away from home on vacation and won’t be back home till December 6. Contact me next month if you had no luck locating the metal fuel line you need. Tony |
PCA Member since 1988
Len Cummings (BoxsterGT) makes all sorts of fuel lines. As long as you're replacing them, consider getting nylon or SS braided versions. The steel ones are a PITA and don't flex when you are working around the engine so they get bent. I have the nylon ones, and no way would I swap them for steel.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
I may change my mind as I keep thinking about the cost of the metal ones!! Last edited by maverck; 11-10-2024 at 04:48 AM.. |
