WUR 80sc ?
Hi all,
Why did 1980 911sc US model get some 0438 140 089 and some get 0438 140 072?
Thanks,
Khuong
Old 10-24-2024, 12:34 PM
AndrewCologne's Avatar
0438 140 089 = ROW SC (with vent connection)
0438 140 072 = US SC (no vent connection) / Engine with lambda control
911 SC 3.0, 1982, black, US model – with own digital CPU based lambda ECU build and digital MAP based ignition control
All you need to know about the 930/16 and 930/07 Lamba based 911 SC US models:
https://nineelevenheaven.wordpress.com/english/
Old 10-24-2024, 02:13 PM
Thanks Andrew.
So my car is ROW right?
Thanks,
Khuong
Old 10-24-2024, 09:36 PM
I don't know which of the WURs is present in your car and even then, you only know the Model/year where that WUR belongs to.
To know what type of engine you got, you should check the engine code, on the engine near the right side of the fan housing:
https://www.stuttcars.com/porsche-911-1965-1989-vin-numbers/#google_vignette
Old 10-25-2024, 12:22 AM
WUR Application…..……
Andrew,
Both WUR-072 and WUR-089 have vent connections. WUR-072 is non-vacuum assisted and for lambda/OXS motors while WUR-089 is a vacuum assisted and for non-lambda/OXS motors. Another difference between these 2 WUR’s is the heater configuration. WUR-072 has a compound heater set-up while WUR-089 has a single heater. And they operate differently. FYI.
Tony
Old 10-25-2024, 01:15 AM
Originally Posted by boyt911sc View Post
Andrew,
Tony
I know the differencies ... and actually I meant the vacuum connection on the ROW model, thx for clarifying here.
Old 10-25-2024, 01:23 AM
Andrew,
You have an excellent website. And I like it very much.
Tony
Old 10-25-2024, 04:53 AM
Thx a lot Tony
Old 10-25-2024, 06:11 AM
Thank you Andrew and Tony.
The 089 is on my 1980 911sc Targa, the ECU with black label and Engine # is *640 1995*.
Thanks.
Khuong
Old 10-25-2024, 11:05 AM
I found this website and yes my is US model and wonder why my car had WUR # 089.and AAV # 0280160324.
https://www.stuttcars.com/porsche-911-engine-numbers-1965-1989/
Thanks.
Khuong
Old 10-25-2024, 11:37 AM
PCA Member since 1988
Does it still have lambda (O2 sensor) connected? Someone probably disabled the lambda system and swapped the 072 for an 089.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 10-25-2024, 01:22 PM
Yes, o2 still connected.
Thanks,
Old 10-25-2024, 09:40 PM
CIS Components Compatibility………..
Thanks,
WUR-089 is not compatible with your lambda/OXS motor. What fuel distributor do you have now? FD-077? And with FV?
Tony
Old 10-26-2024, 02:57 AM
@80 TargaSC
In a nutshell: An ROW (non lambda engine) WUR-089 needs at its vacuum port a higher manifold vacuum to be present so it provides a correct control fuel pressure at normal load/driving.
At high load, means accelerating, the manifold vacuum at the WUR port drops which lets the WUR drop the control pressure as well, so the mixture will be enriched.
Now in your case with a lambda based engine model, as no manifold vacuum hose to the WUR exists, the 089 WUR always sets the control pressure to lower spec and your engine is driving too rich. Additionally ... with your lambda system ..., when engine is cold running or when you accelerate you get an additional enrichment by the ECU!
You see why its one of the worst things driving with a non proper WUR.
I recommend checking your whole system ... follow this workshop and your engine will drive like charm:
https://nineelevenheaven.wordpress.com/the-911-sc-3-0-engine-with-catalyst-and-lambda-control/
Old 10-26-2024, 08:23 AM
Tony
Hi Tony,
The FD is 077 and had FV too.
Thanks,
Khuong
Old 10-26-2024, 11:32 AM
@80 TargaSC
Hi Andrew,
It got vacuum kook up to WWR.
Thanks,
Khuong
Old 10-26-2024, 11:34 AM
in a 1980 model with ECU? Thats weird.
You don't confuse the vent hose with the vacuum hose?
IF really a "vacuum" hose is connected to your 089 WUR, then it would be good to know from which source this vacuum has ben taken, as its not the concept of this particular CIS design.
Old 10-26-2024, 12:07 PM
Hi Andrew,
The vent on the top of WUR has no connection and the source of the vacuum came from The back of TB and a T connected to Decel valve.
Thank,
Khuong
Old 10-26-2024, 12:38 PM
Hi Guys, I have a October 1979 RoW (Therefore 1980 model) and it has a 069 WUR. I am pretty sure it is correct one for the car.
Old 10-26-2024, 12:57 PM
Hi Andrew,
Thank,
Khuong
At least the one, who replaced the correct WUR with that ROW WUR model, knows where on this TB the correct port for a full load bandwidth manifold vacuum is present.
But ... this combination is still not compatible with the ECU concept, as ... if you accelerate then the mixture will be enriched two times, ... by the WUR and by the ECU at the same time.
So .... get yourself the correct WUR :-)
Old 10-27-2024, 03:34 AM
