brake pedal stuck down
I have a 86 Porsche 911 Carrera.
The brake pedal is stuck down. Appears to be alot of rust. I have sprayed it with wd-40 and have used rust remover.
I still can't get it to budge.
We have pushed the car around and appears brake pads, calipers and rotors are ok.
Anyone have any suggestions on to what is going on?
Thanks for your help in advance.
Michael
Old 10-25-2024, 07:53 PM
PCA Member since 1988
It sounds like the pedal cluster is corroded badly. Remove, disassemble, thoroughly clean and install new bushings.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 10-26-2024, 11:01 PM
As Pete says it sounds like the pedal cluster needs a rebuild. There’s plenty of info on here about this relatively simple and inexpensive job so do a search and see of that helps
Old 10-26-2024, 11:56 PM
