KlausMeine's Avatar
Vacuum Lines from intake manifold
Does anyone have the schematics for this vacuum line? I've always assumed it's the brake power booster vacuum line but can't seem to follow the trail. I believe it goes into the tunnel but seems too big for that. I identified a vacuum leak on cylinder 2 coming from this line. Any ideas how to replace it? It's a '79 911 SC with 46mm PMO carbs.
Old 12-27-2024, 06:38 PM
Still here
pmax's Avatar
Yes, goes to the tunnel.
From the engine compartment to under the chassis snakes around the "top" (or bottom depending on your perspective) to a tube in the tunnel, all on the driver's side.
Pic in this thread below from Mr Walker himself.
https://forums.pelicanparts.com/porsche-911-technical-forum/435952-vacuum-leak-you-probably-didnt-ever-think.html
Old 12-27-2024, 08:15 PM
KlausMeine's Avatar
Sigh of relief
Thank you so much for your response. It's good to know I'm not alone with this issue.
Old 12-29-2024, 06:28 PM
