Porsche Crest Pedal box upgrades
Hi All,
I am rebuilding a 1973 911 with a 1976 2.7L motor. This is not a stock rebuild due to the parts I have to replace a I am building. I am trying to make modern upgrades wherever I can.
I have the original pedal box and have rebuilt it will all new bushings and springs. I need new clutch and throttle cables run through the tunnel.
Does anyone have thoughts on the pedal box. Are there newer technology pedal boxes that I can use ?
I know there is a drive by wire pedal from the 80's for the throttle. I wanted to know if I could replace, brake, clutch and throttle into a new set up ??
Thoughts
Jared
73 Porsche 911 Targa
57 Chevy 3100
Old 11-23-2024, 06:21 AM
Bill Verburg's Avatar
Originally Posted by Sparky73 View Post
Hi All,
Thoughts
not really
you have a 19mm non-boosted m/c, from '77 they changed to a 20.6mm boosted m/c, it's not a simple bolt on to change from yours to that.
you could install a dual master setup, but the main reason to do so is some sort of brake bias issue w/ non std. brakes
drive by wire didn't come along until around 2000, new air-cooled 911s were history at that point
Bill Verburg
Old 11-23-2024, 09:32 AM
I made a dual brake master cylinder with hydraulic clutch master cylinder for a G-50 for early 911, 930's. So 3 master cylinders under the floor board, and even added a Accelerator Pedal Position sensor for drive by wire.
Everything fits under the factory floor board and carpet.
https://forums.pelicanparts.com/porsche-911-technical-forum/1160332-early-911-930-pedal-box-scrs-style-dbw-g50-clutch.html
Old 11-23-2024, 10:05 AM
the 3rd m/c is only for a hydraulic clutch not needed in a '72
DBW requires an engine management system that supports it, again not something typically seen in a '72
and lastly unless there is an oddball non std brake setup, why bother
here's a typical twin master setup for a pre '87 911
Bill Verburg
Old 11-23-2024, 10:25 AM
thanks guys. Seems like the easiest thing to do is stick with the original pedal cluster. There's not a lot of room in the early 911's for upgrades. I was just thinking there was a modern upgrade that would be simpler and drive better.
Jared
57 Chevy 3100
Old 11-24-2024, 03:27 PM
