-   Porsche 911 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=8)
-   -   Should I/How to - Clean inside splines of Torsion Tube (http://forums.pelicanparts.com/showthread.php?t=1173022)
ccallana 01-22-2025 01:21 PM
Took my rear torsion bars out - if I look inside the tube, it looks pretty clean, but at the splines looks like some gunk... any reason to try and clean it up? how would I even get in there to clean it without messing things up?
http://forums.pelicanparts.com/uploa...1737580887.jpg
Locker537 01-22-2025 02:25 PM
Bottle brush on the end of a long dowel?
I would not focus on cleaning as much as I would getting enough fresh grease on the torsion bar.
PeteKz 01-22-2025 03:12 PM
Don't worry about it.
I would be a LOT more concerned about the outboard end of the torsion tube. It looks like the cup has rust holes in it.
ccallana 01-22-2025 05:07 PM
I think what you might have thought was rust was just dirt/rubber... cleaned it up a bit.. still looks like some brown stuff, but doesn't seem like rust...
http://forums.pelicanparts.com/uploa...1737594406.jpg
Sailkane 01-22-2025 06:40 PM
Amazon sells a 3” diameter extra long “bottle” brush…cheap
PeteKz 01-23-2025 12:28 AM
That looks better.
superninety 01-24-2025 01:40 PM
I made a giant "Swab". I just took a white towel and taped it on to a long 1" dowel. Swab, change the towel, repeat. I think I sprayed some brake cleaner on it. It took several iterations, but it worked well.
75 911s 01-25-2025 05:44 AM
Friend had me take over his project car. Torsion bars were sticking out of both sides like 30mm. Pulled them and found sand and grit in the inner splines. Used a brass brush on a dowel to clean and then vacuum out all the particles.
Dpmulvan 01-25-2025 07:23 AM
A little heat on the center of the tube helps if it’s not covered with chipgaurd.
