Rear Bumper Pad Alignment
What is the best way to re-align this left rear bumper pad? I've tried pushing on the lower right edge but it won't move.
2018 Porsche 911 GT3 manual
1984 Porsche 911 Carrera Targa
2021 Porsche Macan GTS
2018 BMW R1200GS Adventure Rallye
2020 Ducati Scrambler 1100 Sport Pro
Old 02-20-2025, 12:47 PM
Mark Salvetti's Avatar
Do you know what happened to it? It's odd because the top and the side by the license plate looks fine, it's only the lower portion that seems deformed.
I'm not sure that's fixable. Maybe try a block of wood and a floor jack to carefully push up on it.
Mark
1979 911SC Targa
Old 02-20-2025, 02:25 PM
Mark, when I first got the car I had the rear valance refinished because the area around the tailpipe was a little scratched up, like it had been catching on a slope. I'm sure they had to remove the bumpers, and I think it was just re-installed incorrectly. I didn't really notice it, but now I do and it's bugging me.
Old 02-20-2025, 02:51 PM
Ah. Well, it’s held on by three nuts on the inside. You could try unbolting it and resetting. I’m just not sure that’s the problem, since most of it looks fine.
Pretty sure you will need to remove the muffler to get to the nuts.
Mark
1979 911SC Targa
Old 02-20-2025, 05:21 PM
Thanks Mark!
Old 02-20-2025, 06:31 PM
917_Langheck's Avatar
No need to remove the muffler, just the heat shield that backs up to the rear valence.
Since the buffer studs fit a prescribed pattern in the bumper, there is little adjustment to be made. It's likely the rubber material has taken a set in that configuration or has failed in some way. Rusting of the metal plate that holds the studs is a possible culprit.
Old 02-20-2025, 07:42 PM
ahead of the curve
Jeff Burger's Avatar
the rear valence mounting point was moved more to the back of the bumper at some point (I forget the year they changed) - the rear bumper blocks were different to make them fit correctly when it changed. I suspect the bumper block on the left is the wrong year probably later 3.2. you can pull it off and check the part number molded on the inside.
19 Carrera T - MPS member
92 C2 SR coupe M491/ 3.8 look- manual
92 C2 SR coupe cobolt blue- manual
73 914 1.7 (?) AG -a solid project looking 4 a sugar daddy
73.5 T gemini blue SR coupe sold 8/22 my last long hood gone
Old 02-22-2025, 08:11 AM
Unless that it a modified '74 or '75 Carrera, that is a 3.2 (84-89) Carrera.
Old 02-23-2025, 04:23 PM
ahead of the curve
based on the reflector pre - 87
Old 02-23-2025, 06:03 PM
Based on Joseph's signature, it's a 1984. I think the bumperettes changed in 1986.
Mark
1979 911SC Targa
Old 02-23-2025, 06:34 PM
