I think I'm going to try the car chemistry inserts in my GT3 style Dansk, and can record the difference. Mine drones a little higher--right about 2500--so I need to put something in place. I've used a cap before, which works, but it looks a bit ****.
1982 911SC |
Zink Racer
This is a message I got from Brian about my M&K.
Jerry, The muffler you have is an MKM26 dual out sport muffler. Either side can be capped. The only change in sound volume will depend on which side is capped. Cap the driver's side and all the sound comes out the passenger's side which of course will be a little less loud for you in the driver's seat. We have internal caps that slide inside the tailpipe stub-out and are then captured when the tailpipe is bolted back on. That also allows you to retain the dual out look. ![]() I bought the car chemistry inserts and they do help. I don't have many miles on them yet. I did this toward the end of the driving season last year.
Jerry 1983 911 SC/Carrera Franken car, 1974 914 Bumblebee, 1970 914-4, 1999 323ti |
Do not lug these engines below 3000RPM, it increases head temps tremendous amount. It's the primary reason for failed valve guides! Increased head temps from lugging these engines especial in hot summer climates will quickly destroy valve guides. Ever wonder why some engines need new valve guides at 40K mile while others can go 200K miles with minor guide wear? This is the primary reason.
Sal 1984 911 Carrera Cab M491 (Factory Wide Body) 1975 911S Targa (SOLD) 1964 356SC (SOLD) 1987 Ford Mustang LX 5.0 Convertible |
Have a picture of the muffler you are using? I was curious if the GT3 style muffler outlets droned, thanks for posting.
Still here
![]() OP's situation is about running around town. Downshifting from 2nd at 3000 rpm means 5500 in 1st at a leisurely 30 mph. I would like to know who shifts our beloved 915 like that on the street ! |
And, you can probably only get one or two shifts from 2nd to 1st whilst moving faster than 10 mph before your 915 explodes.
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS Last edited by snbush67; 03-09-2025 at 04:57 PM.. |
Still here
At 30 mph, better off in 2nd above 3K than in 3rd. 2nd is the workhorse around town so there's no getting away from lower rpms than 3K but that doesn't necessarily mean it's lugging the engine, it all depends on the throttle. Last edited by pmax; 03-11-2025 at 03:51 PM.. |
Sal, I have the M&K two in, two out GT3 style on my SC. It does drone, but after adding the baffled tips it is much better. Pretty much all of the 2 in 2 out mufflers drone to some extent.
Did you pack the baffles with wool and use either of the restrictor caps? Mine are being delivered today and I'm not 100% settled on using the restrictor and wool.
1982 911SC |
Zink Racer
I did use the steel wool. I want to say I put the cap with the hole in it on before install but can't remember for sure.
Crotchety Old Bastard
Engine output needs to be considered when adding baffles. If adding packing material to the CC inserts you end up with dual 1-1/2" ID tailpipes. The object is to interrupt the pulse organization at specific RPMs that causes the drone. We typically add butterfly baffles to each tailpipe or internally cap one tailpipe for total elimination. Note that the louder the muffler the more drone can be an issue. Quiet mufflers include the padding or baffling to adequately disturb the annoying pulse organization.
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
BTDT
![]() popular at the car show |
Quit messing with all the hi tech options just stuff a potato in one side
Banned
It's your muffler.
I've been thinking mufflers again and found this thread where I never followed up. I put two car chemistry baffles in my muffler, both with one restictor cap, and packed them with stainless but offset. On the left the packing is in between one baffle pair, on the right it's a different pair. The drone is totally eliminated and I don't get loud pops on the overrun, but it's about the same volume overall. They're easy enough to pull out when I get to the track, too, so I can go full noise.
If I didn't have a wife and a toddler I'd say job well done, but it's unfortunately still too loud to turn it on during nap time.
1982 911SC |
I just ordered the new: SSI HOEING C3.2 PLUS EXHAUST, WITH TWO Ø70 MM TAIL PIPES, DUAL INLETS, Ø41/Ø60 MM HEAT EXCHANGERS.
It’s for my 84 3.2 Carrera. Should I expect any drone? |
![]() This is the new setup! |
Antomero -- while I have no personal experience with this particular setup, dual out mufflers are pretty notorious for droning when installed on our cars. Folks have had good success with mitigating the drone by blocking/capping one of the outlets. Single outlet mufflers generally avoid this droning issue.
I’m hoping this new system was developed and designed to eliminate the associated drone.
Hi,
I also have an M&K 2 in 2 out sport, the drone was really bad. The performance of the system especially the headres is so good, that i am not even mad. I found a solution for the drone, not a quick fix, but a major improvement, maybe brain will use it as the next iteration for the muffler. The pictures are before and after. Best Jonas |
