-   Porsche 911 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=8)
-   -   Help: Question about rear axle shaft replacement (http://forums.pelicanparts.com/showthread.php?t=1175237)
EvoRace 03-16-2025 08:39 AM
Hello,
I need to replace a rear axle shaft on the driver side on my '85 911 Carrera 3.2 (915 trans).
After doing some basic research, I have found two different potential replacement part numbers but I am not sure which one is the correct one (they are both said to fit my car on Pelicans but look quite different):
- Part#: 923-332-033-02-INT:
https://www.pelicanparts.com/More_Info/92333203302.htm?pn=923-332-033-02-INT&srsltid=AfmBOorPvUqjjiY2wzaQPt0K1H_xmOwmhRiWe-IciXiwkomGBtyEFeOf3co
- Part#: 911-332-024-16-M60
https://www.pelicanparts.com/More_Info/91133202416.htm?pn=911-332-024-16-M60&gad_source=1&gclid=Cj0KCQjw7dm-BhCoARIsALFk4v9MNHYLkpU0NyGc3_AiTO-CgWtMFPEQNyo9ftgKkWey-i6nYNL22oAaAlBvEALw_wcB
For context, I found an invoice from Porsche for my car where they replaced the passenger side rear axle a few years ago using the first one that starts with the #923 part number.
1 - Why would the part start with the number "#923" and not a "#911" number?
2 - The two parts look different -- the one with the "#911" number has an extended shaft on the other side of the joint.
Would appreciate any insight and help in figuring out which one I am supposed to get.
Many thanks.
Carlu
http://forums.pelicanparts.com/uploa...1742143127.png
wazzz 03-16-2025 09:55 AM
The 923 is for transmissions 915.67 or 68.
The 911 is for later types. My guess is that you have the early type (923), since that's what you already have on passenger side.
The easiest way to find out is by looking at the CV on the wheel side. If the wheel side has bolts, you need the older (923) type. If you don't see any bolts you need the later 911 type shown above, that is the one that has a non detachable axle and is the most expensive version.
EvoRace 03-16-2025 10:17 AM
Thank you so much, Gilles! I believe I have the bolts on the wheel side so your guess is likely the right one!
Brian Cameron 03-16-2025 12:39 PM
Recommend you download a free copy of the parts Katalog here:
https://assets-v2.porsche.com/ca/-/media/Project/PCOM/SharedSite/PorscheClassic/Original-Parts-Catalogue/PDF-EN-US/KAT507_USA_911_86_KATALOG
Search the PDF for “rear axle” and you will get to these pages, first a diagram, and then on the next page, the part number based on the transmission version:
http://forums.pelicanparts.com/uploa...1742157456.jpg
And the part number info, see detail ar right for the applicable version:
http://forums.pelicanparts.com/uploa...1742157532.jpg
EvoRace 03-17-2025 12:14 AM
Thank you so much, Brian!
911obgyn 03-17-2025 10:52 AM
85 was a transition year, gotta look for bolts.
GH85Carrera 03-17-2025 12:02 PM
Yea, look for what month your car was built. The early cars are different than the latter in the year cars.
Best option, call Pelican Parts, with your VIN and go from there.
ErrorMargin 03-17-2025 03:13 PM
Originally Posted by EvoRace (Post 12429472)
I need to replace a rear axle shaft on the driver side on my '85 911 Carrera 3.2 (915 trans)...
Now would be a good time to review the thread on CV Joints and pay particular attention to the posts from Grady on the CV Joint bolts, washers and moon plates:
https://forums.pelicanparts.com/porsche-911-technical-forum/222537-reconstructing-constant-velocity-cv-joints.html#post1922501
Summary:
Replace any bolts that look damaged with the correct length Class 12.9 bolts (I replaced all of my bolts, several had some damage and I figured I would just start fresh)
Use new Schnorr VS washers
Consider also using moon plates
Torque to 33 ft/lbs
A930Rocket 03-17-2025 08:00 PM
Sorry to go off target here, but is there a searchable database like RealOEM for BMW, but for Porsche?
https://www.realoem.com/bmw/enUS/partgrp?id=BD53-USA-10-2004-E46-BMW-330Ci
Originally Posted by Brian Cameron (Post 12429621)
jkkarrow 03-18-2025 12:50 AM
Get a free copy of the parts Katalog here:
walfreyydo 03-18-2025 05:03 AM
Originally Posted by jkkarrow (Post 12430572)
Suspected bot, keeps reposting the same info from earlier in the thread to boost post count (likely to defraud people on the used parts marketplace). Please report this user
