Tire peeling
Should I be worried about these strips peeling off my PS AS4s?
1986 Carrera 3.2 Coupe in Grand Prix White IG: @c.cal.porsche |
Is your tire rubbing on the inner fender?
Your tire is rubbing on the fender Probably want to figure it out and fix it
07 GT3 Cup S 4.0, 00 986, 78 911 old school gt car 77 BMW R100S 99 Ducati 996S 04 BMW R1150R |
Sure enough - left side is lower than right side - probably even more so once I sit in the car...
Never had any problems until this weekend though.. probably time to put a quick turn on the adjustment, bring it up a bit. then of course may have to re-align
PCA Member since 1988
Especially check camber. A small change in camber will cause or cure that.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
